zoulzubazz
Member level 5
- Joined
- Apr 26, 2012
- Messages
- 87
- Helped
- 3
- Reputation
- 6
- Reaction score
- 3
- Trophy points
- 1,288
- Activity points
- 2,040
hey guys have this dual op-amp howland current source i designed for my purpose using an xr2206 sugnals generating ic and a dual op-amp. the figure shows the design. the circuit gets its input (Csin in the figure) from the xr2206 and the output is being tapped from pin 3 of the op-amp (VCCS in figure).
now to test this circuit i am attaching a shunt resistor in series with a 10kOhm trim pot which is grounded on the other end and observing the voltage across the 100ohm shunt using an oscilloscope also shown (rather crudely) in the figure. ideally the voltage across the shunt should remain constant when the load resistance changes since this is a constant current circuit; which is the case, but when the load is open circuited (essentially opening the current path) the oscilloscope continues shows the same voltage across the shunt? now when the ground-clip of the scope is connected to circuit ground and then the load is changed the voltage across the shunt is observed to be swinging with the change in the trim pot. i dont quiet understand what is going on and would like some help regarding this. thanks very much.
