I am using IBM CMOS 8RF technology, I can pass DRC, LVS smoothly. But when I do the RCX, if I choose, LVS Extracted View as the output, I can easily do and I can get an extracted view without parasistic parameters. If I choose, Extracted View as the output, I almost I can not start the extraction. It report a warinng in the log file as the following.
"Waring" avRCX: The LVS run used ? rulesFile, which overrides the technology directory operation. You must now use the rcxParameter ? rcxSetupDir <path/dir> in the rcxParameters section of the RSF to point to the directory containing the capgen files. A technology setting maybe used in RCX only if technology was used in the LVS run.
Infact, I have filled the Setup Dir with the RCX directory other than LVS directory.
What is going on?
Any help is appreciated!
