kidteam
Junior Member level 3
sorry i am bad in English
i try modify program memory pic16f1509
to read, erase program memory work fine.
but when i write to it
i alway encounter error at first address
code
but code
is work fine
please tell me why?
code
#include <htc.h>
__CONFIG(FOSC_XT&WDTE_OFF&PWRTE_OFF&MCLRE_OFF&CP_OFF&BOREN_OFF&CLKOUTEN_OFF&IESO_OFF&FCMEN_OFF);
__CONFIG(WRT_OFF&STVREN_OFF&LPBOR_OFF&LVP_OFF);
#define _XTAL_FREQ 3686400
#define KT_BOOT_START 0x1e00
void Send(unsigned char d);
void Init_UART(void);
unsigned char Get(void);
unsigned char s2h(unsigned char d);//chuyen tu ascii sang so hexa
void init_timer0(void);//dung de dem gio
void KT_Write(void);//ghi vao vung nho flash
unsigned char count,cnt;//cnt de dem szBuff, count de dem gio
unsigned char szBuff[64];//vung dem chua du lieu
void main() {
char c,bOk;
cnt=0;
init_timer0();
Init_UART();
//sau khi reset thi se cho 15s
//neu sau 15s ma nhan duoc 'K' thi dua vao mode bootload
//gui lai 'Y'
//neu khong thi gui lai 'N'
bOk=0;
Send('T');//bao hieu cho PC biet la da san sang
while(1) {
//cho 15s
while(!TMR0IF) {
if(RCIF) {//co ky tu nhan duoc
c=Get();
if(c=='K') {//neu nhan duoc K la dua vao mode bootloader
bOk=1;
break;
if(bOk)
break;
TMR0IF=0;
++count;
if(count==200)//het gio
break;
if(bOk) {
Send('Y');
} else {
Send('N');
//dang gui cho gui xong ky tu ket thuc da
if(!bOk) {
//chay chuong trinh cu
__delay_ms(10);
#asm
goto _redirect
#endasm
//thuc thi Bootloader
while(1) {
//lan luot lay chuong trinh moi va ghi vao bo nho
c=Get();
//nhan du lieu moi va ghi vao bo nho
switch(c) {
case 'R'://bat dau dong du lieu
cnt=0;
break;
case 'W'://ra lenh ghi vao flash
KT_Write();
break;
default://tang bien dem va luu vao du lieu nhan duoc
szBuff[cnt]=c;
++cnt;
break;
void Init_UART(void) {
ANSELB=0;
TRISB=0;
ANSELA=ANSELC=0;
TRISA=TRISC=0;
TRISB7=0;
TRISB5=1;
//khoi tao EUART truyen
//cho phep truyen
TX9=0;//truyen 8 bit
BRGH=0;
BRG16=0;
SPBRGL=5;
SPBRGH=0;
//9600
TXEN=1;
CREN=1;
SYNC=0;
SPEN=1;
SPEN=0;
SPEN=1;
//co the rut gon lai chi bang it lenh gan hon
unsigned char Get(void) {
while(!RCIF);
return RCREG;
void Send(unsigned char d) {
while(!TXIF);
TXREG=d;
void redirect(void) @ KT_BOOT_START { //voi pic16f1509 phai dam bao 1 vung nho lon hon 32W
//nen ta phai ghi dummy vao vung nho start nay// ton bo nho 24 W vo ich
#asm
PCLATH equ 0Ah
PCL equ 02h
; this must be 4 word in length (including return)
movlw 0
movwf PCLATH
movwf PCL
nop
movlw 0
movwf PCLATH
movwf PCL
nop
movlw 0
movwf PCLATH
movwf PCL
nop
movlw 0
movwf PCLATH
movwf PCL
nop
movlw 0
movwf PCLATH
movwf PCL
nop
movlw 0
movwf PCLATH
movwf PCL
nop
movlw 0
movwf PCLATH
movwf PCL
nop
movlw 0
movwf PCLATH
movwf PCL
nop
#endasm
unsigned char s2h(unsigned char d) {
if(d>='A')
return (d-'A'+10);
return (d-'0');
void init_timer0(void) {
T0CS=0;
PSA=0;
PS0=PS1=PS2=1;//1:256
count=0;
TMR0IF=0;
void KT_Write(void) {
//ghi vung dem vao flash
//cho nhan tiep dia chi can ghi
unsigned char addrhh, addrll,addrhl, addrlh, addrh, addrl,i;
addrhh=Get();
addrhl=Get();
addrlh=Get();
addrll=Get();
GIE=0;
CFGS=0;//ghi vao flash khong ghi eeprom, config
addrh=((s2h(addrhh))<<4)|(s2h(addrhl));
PMADRH=addrh;
addrl=((s2h(addrlh))<<4)|(s2h(addrll));
PMADRL=addrl;
if((0==addrh)&&(0==addrl)) {//page dau tien chua lenh nhay toi ham main cua chuong trinh moi
PMADRL=0;//vung redirect
PMADRH=0X1E;//ghi vao vung redirect
FREE=1;//lenh xoa
WREN=1;
PMCON2=0x55;
PMCON2=0xaa;
WR=1;
#asm
nop
nop
#endasm
WREN=0;
//xoa xong moi ghi du lieu vao
PMADRH=addrh;
PMADRL=addrl;
LWLO=1;//ghi vao latch
FREE=0;//lenh ghi
WREN=1;
for(i=0;i<32;++i) {
//Send(szBuff[0]);
//Send(szBuff[1]);
PMADRL=i;
PMDATH=i;//s2h(0);//du lieu se ghi
PMDATL=i;//s2h(1);
//while(WR);
PMCON2=0x55;
PMCON2=0xaa;
WR=1;
#asm
nop
nop
#endasm
PMADRL=0;
PMDATH=0;//s2h(0);//du lieu se ghi
PMDATL=0;//s2h(1);
//while(WR);
PMCON2=0x55;
PMCON2=0xaa;
WR=1;
#asm
nop
nop
#endasm
//bat dau ghi vao flash
PMADRH=addrh;
PMADRL=addrl;
LWLO=0;
PMCON2=0x55;
PMCON2=0xaa;
WR=1;
#asm
nop
nop
#endasm
WREN=0;
//gui lai thong bao cho PC biet la da ghi xong
Send('O');
#include <htc.h>
void main() {
char c,bOk;
cnt=0;
init_timer0();
Init_UART();
//gui lai 'Y'
bOk=0;
while(1) {
//cho 15s
while(!TMR0IF) {
c=Get();
bOk=1;
break;
if(bOk)
break;
TMR0IF=0;
++count;
break;
if(bOk) {
Send('Y');
} else {
Send('N');
if(!bOk) {
__delay_ms(10);
#asm
goto _redirect
#endasm
while(1) {
c=Get();
switch(c) {
cnt=0;
break;
KT_Write();
break;
szBuff[cnt]=c;
++cnt;
break;
ANSELB=0;
TRISB=0;
ANSELA=ANSELC=0;
TRISA=TRISC=0;
TRISB7=0;
TRISB5=1;
//cho phep truyen
BRGH=0;
BRG16=0;
SPBRGL=5;
SPBRGH=0;
//9600
TXEN=1;
CREN=1;
SYNC=0;
SPEN=1;
SPEN=0;
SPEN=1;
while(!RCIF);
return RCREG;
while(!TXIF);
TXREG=d;
#asm
PCLATH equ 0Ah
PCL equ 02h
movlw 0
movwf PCLATH
movwf PCL
nop
movlw 0
movwf PCLATH
movwf PCL
nop
movlw 0
movwf PCLATH
movwf PCL
nop
movlw 0
movwf PCLATH
movwf PCL
nop
movlw 0
movwf PCLATH
movwf PCL
nop
movlw 0
movwf PCLATH
movwf PCL
nop
movlw 0
movwf PCLATH
movwf PCL
nop
movlw 0
movwf PCLATH
movwf PCL
nop
#endasm
if(d>='A')
return (d-'A'+10);
return (d-'0');
T0CS=0;
PSA=0;
count=0;
TMR0IF=0;
addrhh=Get();
addrhl=Get();
addrlh=Get();
addrll=Get();
GIE=0;
PMADRH=addrh;
PMADRL=addrl;
FREE=1;//lenh xoa
WREN=1;
PMCON2=0x55;
PMCON2=0xaa;
WR=1;
#asm
nop
nop
#endasm
WREN=0;
PMADRH=addrh;
PMADRL=addrl;
FREE=0;//lenh ghi
WREN=1;
for(i=1;i<32;++i) {
//Send(szBuff[0]);
//Send(szBuff[1]);
PMADRL=i;
PMDATL=i;//s2h(1);
//while(WR);
PMCON2=0x55;
PMCON2=0xaa;
WR=1;
#asm
nop
nop
#endasm
PMADRL=0;
PMDATL=0;//s2h(1);
//while(WR);
PMCON2=0x55;
PMCON2=0xaa;
WR=1;
#asm
nop
nop
#endasm
PMADRH=addrh;
PMADRL=addrl;
LWLO=0;
PMCON2=0x55;
PMCON2=0xaa;
WR=1;
#asm
nop
nop
#endasm
WREN=0;
Send('O');
please tell me why?
