Problem with writing serial data into a spreadsheet using Labview
handsprince
i had create a VI to read a serial data and write into a spreadsheet, the problem is data is not write into the spreadsheet, it is only replace the previous value in the spreadsheet. how can i correct it? thanks
Labview and serial
I would recommand you to read the help file in labview or install the helpdesk program that come with labview.
Re: Labview and serial
in your specific case, i think data is overwrite on previous one.
stored previous value in some other exel.
might be work
i think you can use VISAWRITE.vi to solve your problem
Labview and serial
Hi, I didnt see any Spreadsheet write function used here. Ok used the 'Write to Spreadsheet File' from FileI/O and used select the 'Append to File'. This appends the new value with the previous value.
