glioliou
Hello guys,
i have to design a power amplifier using a transistor VMMK-1218 from Avago operating at 10GHz .. Also, i dont demand a lot of gain..4-5 dBm are enough. In order to design it i have follow the appropriate application notes provided by Avago. I am using for board : duroid 5870 er=2.33 and h=0.8mm. The recommended diagram is the following:
but the problem is that they do not specify neither the dimensions of S2,S3 for impedance matching nor the inductance of the 2 shunt microstrip lines used for bias. Hence i made my own calculations. My first problem (which cannot be solved) is that i dont have a simulation softwareand in our lab we dont have vector analyzer for 10GHz . So for testing i use a spectrum analyzer to check the power level. My second problem is amplifiers performance. It is oscillating and i have arround 5 dBm loss. My design is
Do you have any ideas-suggestions why my circuit is oscillating??? Thank you
