Braski
Full Member level 3
- Joined
- Dec 22, 2009
- Messages
- 154
- Helped
- 32
- Reputation
- 64
- Reaction score
- 28
- Trophy points
- 1,308
- Location
- Florence (ITALY)
- Activity points
- 2,384
Hi all,
I designed a custom phase generator via Schematic Editor. Due to large number of ports, i use Encounter to do routing.
This is the flow:
1)schematic editor with IO pins and INOUT pins vdd and gnd
2)export Verilog netlist via Verilog XL
3) import design into Encounter with all the necessary
4) do all p&R steps using vdd and gnd as power nets
5) extract the gds2 and final verilog netlist from Encounter
6) stream in into Virtuoso
7)add vdd and gnd pins to layout
8)DRC
9)LVS vs verilog netlist imported as a schematic
when it comes to extract the final verilog netlist, Encounter does not add vdd and gnd connections to the instances it added, like decaps or buffers for clock tree. If i do connect them by hand, LVS is almost fine (only a DK related problem with decap parameters)
It is boring. Where am i doing a mistake? I think i made some mess with vdd and gnd net. But where?
This is the flow:
8)DRC
