jene2in
Newbie level 6
Is there any problem with using while loop at the start of the program in VHDL and Xilinx ISE. I keep getting parse error. The algorithm that I have will work best with While Loop and so I was wondering if anyone can point out anything with regards to while loop. Here's few lines frm my code:
begin
while (p(0) != 1) loop -- termination condition
--if p(0) = 0 then
if (a(1) = 0 and a(0) = 0) then -- A = 0 (mod 4)
a <= a srl 2; -- divide by 4
g0: MQRTR port map (w => u, m => m, f => u2); -- use MQRTR component
u <= u2;
if s = 0 then -- flag used to indicate the sign of delta
if d(2) = 0 then s <= 1;
end if;
if d(1) = 0 then
d <= d srl 2; -- divide D by 4
else
p <= p srl 1;
s <= 1;
end if;
else
d <= sll 2;
if p(1) <= 0 then
p <= p srl 2;
else
p <= p srl 1;
end if;
end if;
elsif a(0) = 0 then -- check if a is divisible by 2
a <= a srl 1;
g1: MHLV port map(c => u, m => m, d => u1 );
u <= u1;
if s = 0 then
if d(1) = 1 then
s <= 1;
begin
--if p(0) = 0 then
u <= u2;
end if;
if d(1) = 0 then
else
p <= p srl 1;
s <= 1;
end if;
else
d <= sll 2;
if p(1) <= 0 then
p <= p srl 2;
else
p <= p srl 1;
end if;
end if;
a <= a srl 1;
u <= u1;
if s = 0 then
if d(1) = 1 then
s <= 1;
