Problem with using AVR UART to communicate with PC
xinz
Junior Member level 1
I try to use AVR's uart to communicate with my pc but failed so far.
I wrote a code to echo a byte that sent from my pc (hyperterminal,etc) back.
when I sent a byte(char) from hyperterminal, my avr always sent 0x80 back (I tried sent a-z and 0-9)
except for this char: y,i,o,j,k,l,z,x,n,m,8,9. my avr don't sent anything back.
the code:
.INCLUDE "tn2313def.inc"
RJMP Main
Main:
ldi r16, RAMEND
out SPL, r16
clr r17
ldi r16, 51
out UBRRH, r17
out UBRRL, r16
ldi r16, 0b00000110
out UCSRC, r16
ldi r16, (1 << RXEN) | (1 << TXEN)
out UCSRB, r16
readbit:
sbis UCSRA, RXC
rjmp readbit
in r17, UDR
transbit:
sbis UCSRA,UDRE
rjmp transbit
out UDR,r17
rjmp readbit
I used 8MHz crystal, I set UBRR=51 for 9600 baud rate.
I also tried different baudrate, crystal, frame format, other Atiny2313, Atmega8 but the result is failed.
I also can't say my serial port is damaged since I can update my code using AVR910 through serial port.
any solution?
Re: AVR UART problem
First place to start looking, would be the fuse bits. Make sure that fuses are set correctly for the type of crystal you are using.
AVR UART problem
It seems fine,
Just at the end try:
readbit:
sbis UCSRA, RXC
rjmp readbit
in r17, UDR
transbit:
sbis UCSRA,UDRE
rjmp transbit
out UDR,r17
check2:
sbis UCSRA,TXC
rjmp check2
rjmp readbit
Hope it helps.
Tahmid.
thanks.
it's a hardware problem (my dev.board).
when I test it on breadboard everything is ok
