DatsAbk
Member level 3
hello,
I have been trying this out since 3 days and continuously facing the same problem after trying all I know.
The problem I am facing is that when I send a byte the MSB sent is always '1' and the 3rd bit starting from LSB is skipped. A really strange thing.
The data I receive is as under
Sent Data Received Data on other board
0x01 0x81
0x02 0x82
0x03 0x83
0x04 0x80 that is the 3rd bit is skipped in data
0x05 0x81 again 3rd bit is skipped and 8th bit is always '1'
0x06 0x82
0x07 0x83
My code is as below:
0x01 0x81
0x02 0x82
0x03 0x83
0x06 0x82
0x07 0x83
// PIC32MX220F032B Configuration Bit Settings
#include <p32xxxx.h>
// DEVCFG3// USERID = No Setting
#pragma config PMDL1WAY = ON // Peripheral Module Disable Configuration (Allow only one reconfiguration)
#pragma config IOL1WAY = ON // Peripheral Pin Select Configuration (Allow multiple reconfigurations)
#pragma config FUSBIDIO = ON // USB USID Selection (Controlled by the USB Module)
#pragma config FVBUSONIO = ON // USB VBUS ON Selection (Controlled by USB Module)
// DEVCFG2
#pragma config FPLLIDIV = DIV_1 // PLL Input Divider (1x Divider)
#pragma config FPLLMUL = MUL_16 // PLL Multiplier (16x Multiplier)
#pragma config UPLLIDIV = DIV_12 // USB PLL Input Divider (12x Divider)
#pragma config UPLLEN = OFF // USB PLL Enable (Disabled and Bypassed)
#pragma config FPLLODIV = DIV_16 // System PLL Output Clock Divider (PLL Divide by 16)
// DEVCFG1
#pragma config FNOSC = FRCDIV // Oscillator Selection Bits (Fast RC Osc w/Div-by-N (FRCDIV))
#pragma config FSOSCEN = OFF // Secondary Oscillator Enable (Disabled)
#pragma config IESO = ON // Internal/External Switch Over (Enabled)
#pragma config POSCMOD = HS // Primary Oscillator Configuration (HS osc mode)
#pragma config OSCIOFNC = OFF // CLKO Output Signal Active on the OSCO Pin (Disabled)
#pragma config FPBDIV = DIV_4 // Peripheral Clock Divisor (Pb_Clk is Sys_Clk/4)
#pragma config FCKSM = CSDCMD // Clock Switching and Monitor Selection (Clock Switch Disable, FSCM Disabled)
#pragma config WDTPS = PS1048576 // Watchdog Timer Postscaler (1:1048576)
#pragma config WINDIS = OFF // Watchdog Timer Window Enable (Watchdog Timer is in Non-Window Mode)
#pragma config FWDTEN = OFF // Watchdog Timer Enable (WDT Disabled (SWDTEN Bit Controls))
#pragma config FWDTWINSZ = WISZ_25 // Watchdog Timer Window Size (Window Size is 25%)
// DEVCFG0
#pragma config JTAGEN = OFF // JTAG Enable (JTAG Disabled)
#pragma config ICESEL = ICS_PGx1 // ICE/ICD Comm Channel Select (Communicate on PGEC1/PGED1)
#pragma config PWP = OFF // Program Flash Write Protect (Disable)
#pragma config BWP = OFF // Boot Flash Write Protect bit (Protection Disabled)
#pragma config CP = OFF // Code Protect (Protection Disabled)
#define PPSUnLock() {SYSKEY=0x0;SYSKEY=0xAA996655;SYSKEY=0x556699AA;CFGCONbits.IOLOCK=0;}
#define PPSLock() {SYSKEY=0x0;SYSKEY=0xAA996655;SYSKEY=0x556699AA;CFGCONbits.IOLOCK=1;}
void main()
unsigned int i;
unsigned int j=0x000001;
ANSELB=0;
PPSUnLock();
TRISBbits.TRISB3=0;
RPB3Rbits.RPB3R=1;
TRISBbits.TRISB2=1;
U1RXRbits.U1RXR=4;
PPSLock();
U1MODEbits.UEN=0;
U1MODEbits.ON=1;
U1MODEbits.SIDL=0;
U1MODEbits.IREN=0;
U1MODEbits.WAKE=0;
U1MODEbits.LPBACK=0;
U1MODEbits.ABAUD=0;
U1MODEbits.BRGH=1;
U1MODEbits.PDSEL=0;
U1MODEbits.STSEL=0;
U1MODEbits.RXINV=0;
U1STAbits.URXISEL=0;
U1STAbits.UTXISEL=0;
U1STAbits.URXEN=1;
U1STAbits.UTXBRK=0;
U1STAbits.UTXEN=1;
U1STAbits.UTXBF=0;
U1STAbits.TRMT=0;
U1STAbits.ADDEN=0;
U1STAbits.UTXINV=0;
U1BRG=10;
while(1)
while (U1STAbits.UTXBF); // wait until transmit buffer empty
U1TXREG=j;
j=j+1;
for(i=0;i<32750;i++); //Provide a random delay
