shaival132
Junior Member level 1
Hello all,
I want to simulate 8bit LFSR in HSPICE . The following is the code that I have written :
.include technology_file.sp
**** Parameters
.param SUPPLY = 5
.param wp = 1.4u
.param wn = 0.7u
.param lp = 0.2u
.param ln = 0.2u
**** Constant Voltage Sources
Vdd vdd GND SUPPLY
Gnd GND 0 0
VCLK CLK GND PULSE (SUPPLY GND 0 0.005n 0.005n 0.995 2n)
**** Subcircuit Dictionary
.SUBCKT XOR2 input1 input2 output VDD GND
M1 wire1 input1 VDD VDD tsmc18P w=wp l=lp
M2 wire2 input2 VDD VDD tsmc18P w=wp l=lp
M3 wire1 input1 GND GND tsmc18N w=wn l=ln
M4 wire2 input2 GND GND tsmc18N w=wn l=ln
M5 output input1 wire3 VDD tsmc18P w=wp l=lp
M6 wire3 wire2 VDD VDD tsmc18P w=wp l=lp
M7 output wire1 wire4 VDD tsmc18P w=wp l=lp
M8 wire4 input2 VDD VDD tsmc18P w=wp l=lp
M9 output input1 wire5 GND tsmc18N w=wn l=ln
M10 wire5 input2 GND GND tsmc18N w=wn l=ln
M11 output wire1 wire6 GND tsmc18N w=wn l=ln
M12 wire6 wire2 GND GND tsmc18N w=wn l=ln
.ENDS XOR2
.SUBCKT DFF_1 D R Q CLK VDD GND
M0_D Q 2 GND GND tsmc18N w=0.7u l=0.2u
M1_D 2 3 GND GND tsmc18N w=0.7u l=0.2u
M2_D 4 CLK GND GND tsmc18N w=0.7u l=0.2u
M3_D 3 R GND GND tsmc18N w=0.7u l=0.2u
M4_D 5 D GND GND tsmc18N w=0.7u l=0.2u
M5_D 6 7 GND GND tsmc18N w=0.7u l=0.2u
M6_D 3 4 6 GND tsmc18N w=0.7u l=0.2u
M7_D 7 CLK 5 GND tsmc18N w=0.7u l=0.2u
M8_D Q 2 VDD VDD tsmc18P w=1.2u l=0.2u
M9_D 2 3 VDD VDD tsmc18P w=1.2u l=0.2u
M10_D 4 CLK VDD VDD tsmc18P w=1.2u l=0.2u
M11_D 8 D VDD VDD tsmc18P w=1.2u l=0.2u
M12_D 3 R 9 VDD tsmc18P w=1.2u l=0.2u
M13_D 9 CLK 10 VDD tsmc18P w=1.2u l=0.2u
M14_D 10 7 VDD VDD tsmc18P w=1.2u l=0.2u
M15_D 7 4 8 VDD tsmc18P w=1.2u l=0.2u
.ENDS DFF_1
.SUBCKT EIGHT_BIT_LFSR CLK OUTPUT VDD GND
XDFF0 D0 R Q0 CLK VDD GND dff_1 lp=lp ln=ln
XDFF1 Q0 R Q1 CLK VDD GND dff_1 lp=lp ln=ln
XDFF2 Q1 R Q2 CLK VDD GND dff_1 lp=lp ln=ln
XDFF3 Q2 R Q3 CLK VDD GND dff_1 lp=lp ln=ln
XDFF4 Q3 R Q4 CLK VDD GND dff_1 lp=lp ln=ln
XDFF5 Q4 R Q5 CLK VDD GND dff_1 lp=lp ln=ln
XDFF6 Q5 R Q6 CLK VDD GND dff_1 lp=lp ln=ln
XDFF7 Q6 R Q7 CLK VDD GND dff_1 lp=lp ln=ln
XEXOR_A Q1 Q2 output_A VDD GND xor2 lp=lp ln=ln
XEXOR_B Q3 Q7 output_B VDD GND xor2 lp=lp ln=ln
XEXOR_C output_A output_B D0 VDD GND xor2 lp=lp ln=ln
.ENDS EIGHT_BIT_LFSR
**** Instance Section
XU811 U811:CLK U811:OUTPUT U811:VDD U811:GND eight_bit_LFSR
**** AC Analysis
*.option post probe
*.probe V(VDD*) V(OUTPUT*) V(CLK*) I(VDD*)
.tran 100n 20us
.END
While I am running this in Hspice : I keep on getting errors like
_______________________________________________________________________________________
ERROR:
.subckt xor2 input1 input2 output vdd gnd
**error** .ends card missing at readin
>error ***difficulty in reading input
_________________________________________________________________________________________
Can anyone suggest me something to run this successfully ? Have I done something wrong in the way subcircuits are defined ?
Thanking in anticipation
**** Parameters
.param SUPPLY = 5
.param wp = 1.4u
.param wn = 0.7u
.param lp = 0.2u
.param ln = 0.2u
Vdd vdd GND SUPPLY
Gnd GND 0 0
.ENDS XOR2
.ENDS DFF_1
**** AC Analysis
*.option post probe
.tran 100n 20us
.END
ERROR:
