Register Log in
[SOLVED] problem with show values in ISIM
electronical
hello,
I have aproblem with ISIM
I have aprogram that the input of it is array of std_logic_vector.
I wrote a testB for it.in this TB I used an array of integer and convert it to std_logic_vector(5 downto 0) ,when I synt it and then use ISIm ,in the ISIM all negative values are shown "37777777767"(in decimal)
I use thesee library
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.std_logic_signed.all;
use ieee.std_logic_arith.all;
use ieee.numeric_std.all;
guetguet
Member level 1
Can you show you part of your test bench where you convert the array of integer into an array of STD_LOGIC_VECTOR please.
TrickyDicky
Advanced Member level 5
as a note, you should NOT use std_logic_arith and numeric_std in the same file as they conflict. Numeric_std is the IEEE standard library.
Toggle Sidebar
