problem with rtc clock in lcd display with pic16f877a
rangerskm
Full Member level 4
Full Member level 4
i am having problem with my real time which is not displaying in lcd but working with simulation and showing time in it.i am posting the code in it please explain the code and say the problem in it.
first header file is lcd.h
// lcd header file
Lcd_Init();
Lcd_data(unsigned char,unsigned char );
Lcd_Display(unsigned char ,char const *);
set_delay(unsigned char ,unsigned int );
Lcd_Decimal(unsigned char ,unsigned int ,unsigned char );
Lcd_write(unsigned char ,unsigned char );
#define rs RD0
#define en RD1
#define dat_port PORTD
Lcd_Init()
	Lcd_data(0x02,0);
	Lcd_data(0x28,0);
	Lcd_data(0x0c,0);
	Lcd_data(0x06,0);
	Lcd_data(0x01,0);
Lcd_data(unsigned char x,unsigned char y)
	unsigned char a,b,t;
	a=  x & 0xf0;
	b= (x<<4) & 0xf0;
	t=dat_port & 0x0f;
	dat_port=a|t;
	rs=y;
	en=1;set_delay(1,250);
	en=0;
	t=dat_port & 0x0f;
	dat_port=b|t;
	rs=y;
	en=0;
Lcd_write(unsigned char x,unsigned char y)
	Lcd_data(x,0);//command_mode
	Lcd_data(y,1);//data_mode
Lcd_Display(unsigned char x,char const *y)
	Lcd_data(x,0); //command mode
	while(*y!='\0')Lcd_data(*y++,1); //data mode
Lcd_Decimal(unsigned char x,unsigned int y,unsigned char n)
	Lcd_data(x,0);
	unsigned int m=1;
	while(n--)m=m*10;
	while(m>1)
		Lcd_data((y%m)/(m/10)+0x30 , 1);
		m=m/10;
set_delay(unsigned char x,unsigned int y)
	while(x--)while(y--);
second header file is rtc.h
//rtc header file
#define sda_dir TRISC4
#define scl_dir TRISC3
#define i2c_sp 100 //kbps
#define xtal_freq 4000000
i2c_init();
i2c_start();
i2c_stop();
i2c_write_byte(unsigned char );
unsigned char i2c_read_byte();
i2c_restart();
set_time(unsigned char ,unsigned char ,unsigned char ,unsigned char );
get_time(unsigned char );
#define i2c_sp 100
i2c_init();
i2c_start();
i2c_stop();
i2c_restart();
i2c_init()
	sda_dir=1;
	scl_dir=1;
	SSPADD=((xtal_freq/4000)/i2c_sp)-1;
	SSPSTAT=0x80;
	SSPCON=0x28;
i2c_start()
	SEN=1;
	while(!SSPIF);
	SSPIF=0;
i2c_stop()
	PEN=1;
	while(!SSPIF);
	SSPIF=0;
i2c_restart()
	RSEN=1;
	while(!SSPIF);
	SSPIF=0;
i2c_write_byte(unsigned char x)
	SSPBUF=x;
	while(!SSPIF);
	SSPIF=0;
	while(ACKSTAT);
	RCEN=1;
	while(!SSPIF);
	SSPIF=0;
	return SSPBUF;
set_time(unsigned char loc,unsigned char a,unsigned char b,unsigned char c)
	i2c_start();
	i2c_write_byte(0xd0);
	i2c_write_byte(loc);
	i2c_write_byte(a);i2c_write_byte(b);i2c_write_byte(c);
	i2c_stop();
get_time(unsigned char loc)
	unsigned char v,i,j,k;
	i2c_start();
	i2c_restart();
	i2c_write_byte(0xd1);
	v=i2c_read_byte();
	i2c_stop();
	i=(v>>4)&0x0f;
	j= v & 0x0f;
	k=i*10+j;
	return(k);
third one is main file
#include<pic.h>
#include"pic_lcd.h"
#include"rtc.h"
unsigned char i,x[]={0x80,0x87,0x8d,0,0xc0,0xc7,0xcd},b;
main()
	TRISD=0x00;
	Lcd_Init();
	Lcd_Display(0x80,"----------------");
	Lcd_Display(0xc0,"----------------");
	i2c_init();
	set_time(0,0x15,0x30,0x00);set_delay(1,10);
	set_time(4,0x22,0x06,0x11);set_delay(1,10);
	while(1)
		for(i=0;i<7;i++)
			if(i==3)continue;
			b=get_time(i);
			Lcd_Decimal(x[i],b,2);
			set_delay(1,25);
i have posted full code here it will be help full for many people who wants rtc code for pic 16f877a
compiled used hi tech c compiler, mplab
please explain the code and problem for not display in the lcd .
my lcd shows blank .i adjusted the contrast many time but no effect
