elenappli
- Joined
- May 22, 2014
- Messages
- 5
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 63
Hi I just got a custom fpga board in house and I am having trouble programming it.
I am using Actel's(Microsemi) IGLOO AGL250V-FG144I. There is a 10-pin jtag header on board. To program I am using Actel's FlashPro3. It has a 12 pin jtag header, with an extra pin called VJTAGENB that is for IGLOOnano device so I have left that pin unconnected. When I go to program the device I get the following error messages.
Error: programmer '71917' : Signal Integrity Failure
Integrity Check Pattern Not Found.
Integrity Check Pattern :
550FAAF000FF0000FFFF
IrScan Error.
TDO stuck at 0
Chain Analysis Failed.
Error: programmer '71917' : Data Bit length : 8272
Error: programmer '71917' : Compare Data : 00010808000024000041144885248008068649....
Error: programmer '71917' : Scan Chain FAILED.
I have scoped out the jtag lines pictures are below:
TCK and TDI
TCK and TDO
TCK and TMS
TCK and TRST
The Volt per grid line is 1V
I have tried two boards and they both get the same error and the scope plots look the same. According to microsemi's app note on programming with flashpro this error could indicate a bad TDO connections. Are there any other possible causes? The TMS and TR plots look wrong were TDO looks right. Any advice on how to further debug this?
Thanks!
IrScan Error.
TDO stuck at 0
TCK and TDI
TCK and TDO
TCK and TMS
TCK and TRST
Thanks!
