problem with process
nats_
Newbie level 6
Newbie level 6
in the following code, the process doesn't seem to get beyond the elsif statement. any ideas why?
  architecture div_arch of divider is
signal clks,resets,loads,divs: std_logic;
signal data_ins,data_outs :std_logic_vector(G_DIVIDER_SIZE-1 downto 0);
 begin
   data_ins<=DATA_IN;
   clks <=CLK;
   resets<=RESET;
   loads<=LOAD;
   divs<=DIV;
   DATA_OUT<=data_outs;
  main_sync : process (CLKs,RESETs,divs,loads)
  begin
    if RESETs = '1' then
      DATA_OUTs <=(others => '0');
    elsif CLKs'event and CLKs = '1' then
       if loads='1' and divs='0' then
          DATA_OUTs <= DATA_INs;
          end if;
        if loads='1' and divs='1' then
        DATA_OUTs <='0' & DATA_INs(G_DIVIDER_SIZE-1 downto 1)  ;
      end if;
    end if; -- clk if
  end process;
end div_arch;
It's hard to say without the simulation setup: are you sure the reset signal is deasserted? As you sure the clock signal has appropriate rising edges?
Cheers
LaTeX Commands Quick-Menu:
