Problem with Pole zero analysis using multisim
sagar_echip
Newbie level 6
When I tried to find input impedance function's pole zero of a parallel LC network using Multisim
pole zero analysis, I get following message
| | doAnalyses: matrix is singular
| | pz simulation(s) aborted "
The circuit as well as log file attached.
How to correctly perform pole zero analysis?
  • parallel LC.txt
The answer is given by the program: The lossless LC tank creates a singularity. To be realistic you must add some losses.
