[PIC] Problem with pic i/0 port
naveen.kumar
hello guys,
i am using pic18f4520 and iam making RA4 , RA5 ,RE0 and RE1 as input and i have connected pull up resistor as well but except RA4 all others are going inside the loop even though it is not grounded.
this is my program.....please help me out...
#include<p18f4520.h>
//#include"sutures_gloves_testing.h"
#pragma config OSC = HS 		//INTOSC_EC
#pragma config PWRT = OFF
#pragma config  BOREN  = OFF
#pragma config MCLRE = ON
#pragma config PBADEN = OFF
#pragma config LVP = OFF
#pragma config WDT = OFF		//,DEBUG=OFF
#define LED1  (LATBbits.LATB3)
#define LED2  (LATBbits.LATB2)
#define LED3  (LATCbits.LATC5)
#define LED4  (LATCbits.LATC4)
#define SWITCH_1 (PORTAbits.RA4)
#define SWITCH_2 (PORTAbits.RA5)
#define SWITCH_3 (PORTEbits.RE0)
#define SWITCH_4 (PORTEbits.RE1)
#define Actuator_1 (LATAbits.LATA0)
#define Actuator_2 (LATAbits.LATA1)
#define Actuator_3 (LATAbits.LATA2)
#define Actuator_4 (LATAbits.LATA3)
#define Solenoid_1 (LATCbits.LATC2)
void All_init(void);
void main()
	All_init();
	Actuator_1 = 1;
	Actuator_2 = 1;
	Actuator_3 = 1;
	Actuator_4 = 1;
	while(1)
	        if(SWITCH_1 == 0)
		Actuator_1 = 0;
		if(SWITCH_2 == 0)
		Actuator_2 = 0;
		if(SWITCH_3 == 0)
		Actuator_3 = 0;
		if(SWITCH_4 == 0)
		Actuator_4 = 0;
	//Actuator_2 = 0;
void All_init()
	TRISBbits.RB3 = 0;
	TRISBbits.RB2 = 0;
	TRISCbits.RC5 = 0;
	TRISCbits.RC4 = 0;
	TRISCbits.RC2 = 0;
    TRISAbits.RA0 = 0;
	TRISAbits.RA1 = 0;
	TRISAbits.RA2 = 0;
	TRISAbits.RA3 = 0;
	TRISAbits.RA4 = 1;
	TRISAbits.TRISA5 = 1;
	TRISEbits.RE0 = 1;
	TRISEbits.RE1 = 1;
You have to use debounce delays for each switch.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
#include <delays.h>
#pragma config PWRT   = ON
#pragma config BOREN  = ON
#pragma config DEBUG  = OFF
#define LED1  LATBbits.LATB3
#define LED2  LATBbits.LATB2
#define LED3  LATCbits.LATC5
#define LED4  LATCbits.LATC4
#define SWITCH_1 PORTAbits.RA4
#define SWITCH_2 PORTAbits.RA5
#define SWITCH_3 PORTEbits.RE0
#define SWITCH_4 PORTEbits.RE1
#define Actuator_1 LATAbits.LATA0
#define Actuator_2 LATAbits.LATA1
#define Actuator_3 LATAbits.LATA2
#define Actuator_4 LATAbits.LATA3
#define Solenoid_1 LATCbits.LATC2
void All_init()
    TRISBbits.TRISB3 = 0;
    TRISBbits.TRISB2 = 0;
    TRISCbits.TRISC5 = 0;
    TRISCbits.TRISC4 = 0;
    TRISCbits.TRISC2 = 0;
 TRISAbits.TRISA0 = 0;
    TRISAbits.TRISA1 = 0;
    TRISAbits.TRISA2 = 0;
    TRISAbits.TRISA3 = 0;
    TRISAbits.TRISA4 = 1;
    TRISEbits.TRISE0 = 1;
    TRISEbits.TRISE1 = 1;
    ADCON1 = 0x0F;
    CMCON = 0x07;
    CVRCON = 0x00;
void main()
    All_init();
    Actuator_1 = 1;
    Actuator_2 = 1;
    Actuator_3 = 1;
    Actuator_4 = 1;
    while(1)
            if(SWITCH_1 == 0)
            Delay1KTCYx(0);
            if(SWITCH_1 == 0)
                Actuator_1 = 0;
        if(SWITCH_2 == 0)
            Delay1KTCYx(0);
            if(SWITCH_2 == 0)
                Actuator_2 = 0;
        if(SWITCH_3 == 0)
            Delay1KTCYx(0);
            if(SWITCH_3 == 0)
                Actuator_3 = 0;
        if(SWITCH_4 == 0)
            Delay1KTCYx(0);
            if(SWITCH_4 == 0)
                Actuator_4 = 0;
    V
so SWITCH_1 is not working your code right ? and why are u using this stuff like
TRISAbits.RA4 = 1;
thank u for your reply,
ya i ll use it but now i am using debugger to check but still it is entering the loop even though pin is getting 5v.
