pratzz
Member level 5
list p=PIC16F877a
#include <p16F877a.inc>
errorlevel -302
__config _HS_OSC & _WDT_OFF & _LVP_OFF
; SPECIAL FUNCTION REGISTERS
;*******************Macro definitions*****************************
WRITE_ADDR equ b'10100000' ; Control byte for write operations
READ_ADDR equ b'10100001' ; Control byte for read operations
rs equ 0
rw equ 1
en equ 2
;*******************Include file**********************************
; GENERAL PURPOSE REGISTERS
CBLOCK 20h
count
count1
count3
count4
dat
disp
number
bytecount
temp
ENDC
ORG 0
clrf STATUS
movlw 00
movwf PCLATH
goto start
org 04
retfie
table
movlw HIGH $
movwf PCLATH
movf count1,w
addwf PCL,f
dt ' ',' ',' ',' ',' ','E','X','C','E','L',' ',' ',' ',' ',' ',' '
dt ' ',' ','T','E','C','H','N','O','L','O','G','I','E','S',' ',' '
table1
movlw HIGH $
movwf PCLATH
movf temp,w
addwf PCL,f
dt " EEPROM "
movlw 0c0h
call lcd_cmd
dt " WRITE DONE ",0
lcd_cmd
movwf PORTD
bcf PORTB,rs
bcf PORTB,rw
bsf PORTB,en
call delay
bcf PORTB,en
retlw 00h
lcd_data
movwf PORTD
bsf PORTB,rs
bcf PORTB,rw
bsf PORTB,en
call delay
bcf PORTB,en
retlw 00h
lcd_init
movlw 38h
call lcd_cmd
call delay
movlw 0eh
call lcd_cmd
call delay
movlw 01h
call lcd_cmd
call delay
movlw 06h
call lcd_cmd
call delay
movlw 80h
call lcd_cmd
call delay
call delay
retlw 00h
delay
movlw 02h
movwf count3
here2 movlw 0ffh
movwf count4
here decfsz count4,1
goto here
decfsz count3,1
goto here2
retlw 00h
initialise
clrf temp
clrf count
clrf count1
bcf STATUS,RP1
bsf STATUS,RP0
clrf TRISB
clrf TRISD
movlw b'00000111'
movwf ADCON1
movlw b'11111111'
movwf TRISC ; Set PORTC to all inputs
clrf SSPSTAT ; Disable SMBus inputs
bsf SSPSTAT,SMP ; Disable slew rate control
movlw 09h ; Load 0x18 into WREG
movwf SSPADD ; Setup 100 kHz I2C clock
clrf SSPCON2
bcf STATUS,RP0
movlw b'00101000'
movwf SSPCON ; Enable SSP, select I2C Master mode
bcf PIR1,SSPIF ; Clear SSP interrupt flag
bcf PIR2,BCLIF
retlw 00
genstart
bcf STATUS,RP1
bcf STATUS,RP0 ; Select Bank 00
bsf STATUS,RP0 ; Select Bank 01
bsf SSPCON2,SEN ; Generate Start condition
start_wait
btfss PIR1,SSPIF ; Check if operation completed
goto start_wait ; If not, keep checking
retlw 0
genstop
bcf STATUS,RP1
bsf SSPCON2,PEN ; Generate Stop condition
stop_wait
goto stop_wait ; If not, keep checking
retlw 00
genrepstart
bcf STATUS,RP1
bsf SSPCON2,RSEN ; Generate Restart condition
repstart_wait
goto repstart_wait ; If not, keep checking
retlw 0
transmit
bcf STATUS,RP1
movf dat,W ; Copy dat to WREG
movwf SSPBUF ; Write byte out to device
tx_wait
goto tx_wait ; If not, keep checking
bcf PIR1,SSPIF
; bsf STATUS,RP0 ; Select Bank 01
; btfsc SSPCON2,ACKSTAT ; Check if ACK bit was received
; goto ackfailed ; This executes if no ACK received
retlw 00h
pagewrite
bcf STATUS,RP1
movlw 08h
movwf bytecount ; Initialize counter to 16 bytes
call genstart ; Generate start bit
; Now we send the control byte
movlw WRITE_ADDR
movwf dat ; Copy control byte to buffer
call transmit ; Output control byte to device
; Send word address high byte
movf count,W ; Use 0x5A for address to send
movwf dat ; Copy address to buffer
call transmit
txbyte ; This loop transfers all 16 of
call table ; the data bytes to the device
incf count,1 ; Use bytecount as data value
movwf dat ; Copy data to buffer
call transmit ; Output data to device
decfsz bytecount,F ; Check if finished looping
goto txbyte ; Continue looping
call genstop ; Generate stop bit
;call Poll ; Poll for write completion
retlw 0
; Main program starts
start call initialise
call lcd_init
call pagewrite
call pagewrite
call pagewrite
call pagewrite
y call table1
iorlw 00h
btfsc STATUS,Z
goto x
call lcd_data
incf temp,1
goto y
x goto x
end
