[SOLVED] problem with nonblocking assignment
dipin
Full Member level 4
Full Member level 4
hi,
       end else if(!o_complete) begin
                temp_in_data   = temp_in_data << 2;
               if(count > 0) begin
                   substraction  = temp_in_data[15:8] - temp_sub_result[7:0];
                    if(substraction >= 0) begin
this is my code. i think in sequential ,we need to use nonblocking assignment... but if i put put nonblocking assignment then iam not getting the result.my idea is
the shifted data must used in substraction,
and after only completion of substraction ,i need to check weather it is + or _ve and do the rest . so if i do like this is it synthesizable in fpga??
if it is not possible ,,any other methode to do nonblocking assignment instead of blocking assignment?
thanks and regards
hi,
               if(count > 0) begin
Because you aren't "think in sequential". Your code is written like an imperative program.
my idea is the shifted data must used in substraction, and after only completion of substraction ,i need to check weather it is + or _ve and do the rest . so if i do like this is it synthesizable in fpga??
Not if it is a sequential (@ (posedge clk)) clocked block.
Your problem doesn't lay with the blocking/non-blocking it's due to your lack of understanding what hardware you are trying to describe.
If you don't know what your circuit looks like, where the registers and logic are, how the pipeline is structured, then there is likely no way you'll write HDL code that will represent hardware. Therefore you end up with something that looks like a cross between a software program meets Verilog.
Try drawing both a timing diagram and a detailed block diagram showing the processing pipeline, with each stage of registers and how the processing is accomplished. Once you've done the "design" then you can bang away on the keyboard turning the design into HDL code.
Regards
Yup. Exactly this!
Reactions: dipin
    dipin
hi
thanks for the replay.iam a beginer. actually my problem isthis, with in a single clock cycle
i need to assign a value to a register and with in the same clock i need to assign that register to another register.
         a_out_data     <=  a_out_data << 1;
         a_out_data[0]  <=  1'b1;
         temp_sub_result[5:2]  <= a_out_data[3:0];
before this step i am doing some calculation using temp_sub_result..
thanks
It's not generally impossible to pass several steps of data manipulation in a single clock cycle. In this case, blocking assignments may be used in sequential logic. But you should consider that timing closure becomes difficult at higher clock speed. And probably more important for a beginner, the code looses it straightforward style.
Verilog rules require in any case, that a particular variable has to be used on the left-hand side of either non-blocking (the regular case) or blocking assignments, but never both. The variables with non blocking assignment can be seen as intermediate results, like substraction in your example. If timing closure can be still achieved, it's O.K. to use it this way.
I should add, ads-ee is right nevertheless, that blocking asssignments in sequential code involve an abstraction from hardware description and bring up the risk of writing inefficient Verilog code. The usual way of effective logic hardware design is to serialize calculations over several clock cycles with registers holding the intermediate results. In so far it's a useful restriction to write sequential code without any blocking assignments.
Reactions: dipin
    dipin
hi
thanks
Then you need to use the concatenation operation instead of the << 1 (shift left by 1). (your software background is showing ;-) )
What you want is this:
Code Verilog - [expand]
a_out_data <= {a_out_data[2:0], 1'b1}; // This is a very hardware-ish way of looking at a shift operation
// this is equivalent to typing out
a_out_data[3] <= a_out_data[2];
a_out_data[2] <= a_out_data[1];
a_out_data[1] <= a_out_data[0];
Regards
Reactions: dipin
    dipin
