[AVR] problem with mp3 code in avr studio
ghoola
Member level 2
Member level 2
india
what are those error saying please help me?
../FAT/FAT.c:427: warning: passing argument 1 of '__eewr_byte_m8' makes pointer from integer without a cast
../FAT/FAT.c:428: warning: passing argument 1 of '__eewr_byte_m8' makes pointer from integer without a cast
../FAT/FAT.c:429: warning: passing argument 1 of '__eewr_byte_m8' makes pointer from integer without a cast
../FAT/FAT.c:430: warning: passing argument 1 of '__eewr_byte_m8' makes pointer from integer without a cast
../FAT/FAT.c: In function 'GetFolderCluster':
../FAT/FAT.c:436: warning: passing argument 1 of '__eerd_byte_m8' makes pointer from integer without a cast
../FAT/FAT.c:438: warning: passing argument 1 of '__eerd_byte_m8' makes pointer from integer without a cast
../FAT/FAT.c:440: warning: passing argument 1 of '__eerd_byte_m8' makes pointer from integer without a cast
../FAT/FAT.c:442: warning: passing argument 1 of '__eerd_byte_m8' makes pointer from integer without a cast
../FAT/FAT.c: In function 'SearchInit':
../FAT/FAT.c:586: warning: control reaches end of non-void function
the main code is
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
350
351
352
353
354
355
356
357
358
359
360
361
362
363
364
365
366
367
368
369
370
371
372
373
374
375
376
377
378
379
380
381
382
383
384
385
386
387
388
389
390
391
392
393
394
395
396
397
398
399
400
401
402
403
404
405
406
407
408
409
410
411
412
413
414
415
416
417
418
419
420
421
422
423
424
425
#include<avr/io.h>
#include"MMC_SD/MMC_SD.h" //head files
#include"FAT/FAT.h"
#include"VS1003B/VS1003B.h"
#include<avr/pgmspace.h>
#define uint8 unsigned char
#define uint16 unsigned int
#define uint32 unsigned long
#if FIX_DIRECTORY
#define PATH (unsigned char *)("\\music")
#endif
//It's the path where the file placed
//Change it if you want to placed it to anoter foler
//The path should not have blanks, and each foler name's length should less than 8 with no extention
//diagnose and state indicate leds
//at start up this two led indicate error
//at normal they indicate the state of the MODE
#define LED1_CON() DDRC|=_BV(PC5)
#define LED1_ON()  PORTC|=_BV(PC5)
#define LED1_OFF() PORTC&=~_BV(PC5)
#define LED2_CON() DDRB|=_BV(PB1)
#define LED2_ON()  PORTB|=_BV(PB1)
#define LED2_OFF() PORTB&=~_BV(PB1)
//keys
#define STOP _BV(PD2)
#define MODE _BV(PD3)
#define NEXT _BV(PD7)
#define UP   _BV(PD4)
#define DOWN _BV(PD6)
#define PREV _BV(PD5)
#define MP3 1
#define WMA 2
#define MID 3
//mode
#define REPET_ALL 0
#define REPET_ONE 1
#define RANDOM    2
extern uint16 SectorsPerClust;//ÿ´ØÉÈÇøÊý
extern uint16 FirstDataSector;//µÚÒ»¸öÊý¾ÝÉÈÇøÊý   //struct of file information
extern uint8  FAT32_Enable;
struct FileInfoStruct FileInfo;//ÎļþÐÅÏ¢
struct direntry MusicInfo;  //Òª²¥·ÅµÄmp3ÎļþÐÅÏ¢       //the mp3 file item whichi will be played
uint16 totalsongs;          //×ܵÄÒôÀÖÎļþÊýÄ¿          //total songs in the root directery on the SD card
uint8 type;                 //ÎļþÀàÐÍ                  //file type
uint8 track[128];           //stroe the information of songs (bit set indicate songs has been played)
void ClearTrackInfo()       //cleare the array track[128]
    uint8 i;
    for(i=0;i<128;i++)track[i] = 0;
uint8 SetTrack(uint16 songs)//set the track bit, return 1 means the song has been played
    uint8 byte_offset;
    uint8 bit_offset;
    songs--;
    byte_offset = songs/8;
    bit_offset = songs%8;
    if(track[byte_offset] & (1<<bit_offset))return 1;
    else
        track[byte_offset] |= 1<<bit_offset;
        return 0;
void Delay(uint16 n)//ÑÓʱ
    while(n--)asm("nop");
//Timer initialization offer seed of the srandom()
void Timer1_Initial()
 TCNT1H=0x00;
 TCNT1L=0x00;
 TCCR1B=0x01;//system clock;
 ICR1H=0xff;
 ICR1L=0xff;
void PlayMusic()//²¥·ÅÒôÀÖº¯Êý£¬Ò»µ©Ö´Ðв»»áÍ˳ö
    uint16 keylen;          //ÓÃÓÚ¼ü´¦Àí      //for key processing
    uint16 count;           //Êý¾Ý¼ÆÊý          //data counting
    uint8 i;                //Ñ*»·±äÁ¿           //loop variable
    uint16 j;               //Ñ*»·±äÁ¿           //loop variable
    uint32 p;               //´Øָʾֵ          //cluster
    uint32 totalsect;       //ÎļþÓµÓеÄÉÈÇøÊý  //cotain the total sector number of a file
    uint16 leftbytes;       //Ê£Óà×Ö½Ú          //cotain the left bytes number of a file //the last cluster usually not fully occupied by the file
    uint8 *buffer;          //»º³å              //buffer
    uint32 sector;          //ÉÈÇø              //recor the current sector to judge the end sector
    uint8 flag;             //²¥·Å/ÔÝÍ£±êÖ¾     //flag of pause
    uint16 vol=DefaultVolume;//³õʼÒôÁ¿£¬Ó¦Óëvs1003º¯ÊýÀïµÄ³õʼÒôÁ¿Ïàͬ   //default volume
    uint16 songs=1;         //ĬÈϷŵÚÒ»Ê×¸è  //play the fist songs by default
    uint8 mode=DEFAULT_MODE;//µ¥ÇúÖظ´          //repet all by default
    uint16 songs_cnt = 0;                   //how many songs have been played
    if(totalsongs==0)return;//Èç¹ûûÓиèÇúÔòÒì³£Í˳ö  //if no music file return
    uint32 rand_val;
    Timer1_Initial();//Æô¶¯¶¨Ê±Æ÷£¬ÓÃÓÚ²úÉúËæ»úº¯ÊýµÄÖÖ×Ó //initialize the timer
    ClearTrackInfo();
next://ÏÂÒ»Ê׸èµÄÆðʼµØ·½                     //label for "goto"
    if(mode==RANDOM)//Ëæ»ú²¥·Å¸èÇú              //if the mode is shuffle the songs
        songs_cnt++;
        if(songs_cnt == totalsongs && totalsongs<1025)
            ClearTrackInfo();
            songs_cnt = 0;
        rand_val = TCNT1;
        Delay((random() && 0x00ff));
        rand_val <<= 16;
        rand_val += TCNT1;
        srandom(rand_val);
        if(totalsongs>1024)
            songs = (uint16)(((random()/214749)*(uint32)totalsongs)/10000)+1;//Ëæ»ú²úÉú¸èÇúÐòºÅ //create random song number
        while(totalsongs<1025)
            if(SetTrack(songs) == 0)break;
    count=0;//Çå»ùÊý  //clear count
    flag=1;
    while(count<2048 && (type != MID))//recommand 2048 zeros honoring DREQ befor soft reset
    {                                   //ÓÃÓÚ´ÓwmaÌø³öµ½ÏÂÒ»Ê׸裬ºÍÒ»Ê׸è½áÊøÌî³äÊý¾Ý//midi¸ñʽ²»ÐèÒª
        if((VS1003B_PIN & _BV(VS1003B_DREQ))!=0)
            for(j=0;j<32;j++)
                VS1003B_WriteDAT(0x00);//Ìî³ä0  //fill 0
                count++;
            if(count == 2047)break;
    VS1003B_SoftReset();//soft reset //in case of playing wma files//Èí¼þ¸´Î»
#if FIX_DIRECTORY
    Search(PATH,&MusicInfo,&songs,&type);       //ÕÒµ½ÏàÓ¦µÄÎļþ      //find the file
#else
    Search(&MusicInfo,&songs,&type);        //ÕÒµ½ÏàÓ¦µÄÎļþ      //find the file
#endif
    p     = MusicInfo.deStartCluster+(((uint32)MusicInfo.deHighClust)<<16);//¶ÁÎļþÊ×´Ø   //the first cluster of the file
    totalsect = MusicInfo.deFileSize/512; //¼ÆËãÉÈÇøÊý            //calculate the total sectors
    leftbytes = MusicInfo.deFileSize%512; //¼ÆËãÊ£ÓàµÄ×Ö½ÚÊý    //calculate the left bytes
    i=0;
    sector=0;
    while(1)
        keylen=0;
        for(;i<SectorsPerClust;i++)     //Ò»¸ö´Ø  //a cluster
            buffer=malloc(512);
            FAT_LoadPartCluster(p,i,buffer);//¶ÁÒ»¸öÉÈÇø  //read a sector
            count=0;
            while(count<512)
                if(flag==0){if(keylen){Delay(100);keylen--;}}
                else if(type == MID){if(keylen){Delay(100);keylen--;}}
                if((VS1003B_PIN & _BV(VS1003B_DREQ))!=0 && flag)    //¸ù¾ÝÐèÒªËÍÊý¾Ý  //send data  honoring DREQ
                    for(j=0;j<32;j++)           //ÿ´ÎËÍ32¸öÊý¾Ý        //32 Bytes each time
                        VS1003B_WriteDAT(buffer[count]);
                        count++;
                    if(keylen)keylen--;         //ÓÃÓÚ¼ü´¦Àí          //for key processing
                    if(sector == totalsect && count >= leftbytes)       //Èç¹ûÎļþÒѽáÊø      //if this is the end of the file
                        if(type == MID)//waiting the midi file was decoded
                        {//¶ÔÓÚmidÒôÀÖÒª½Ó×ÅËÍ2048¸öÁã
                            count=0;
                            while(count<2048)//recommand 2048 zeros honoring DREQ goto next songs
                                if((VS1003B_PIN & _BV(VS1003B_DREQ))!=0 )
                                    for(j=0;j<32;j++)
                                        count++;
                        i=SectorsPerClust;
                        break;
                    }//Îļþ½áÊø         //file ended
                    if(count == 511){break;}//512×Ö½ÚËÍÍêÌø³ö       //break if a sector was sent
                if((PIND&STOP)==0 /*&& keylen==0*/)//²¥·ÅÔÝÍ£¼ü       //key PLAY/PAUSE
                    Delay(100);
                    if(!(PIND&STOP))
                        while(!(PIND&STOP));
                         if(flag)flag=0;
                         else flag=1;
                         Delay(1000);
                else if(!(PIND&DOWN) && keylen==0)  //ÒôÁ¿-         //Volume down
                    Delay(100);
                    if(!(PIND&DOWN))
                    keylen=200;
                       vol=vol+((uint16)(1<<8)+1);
                       if(vol>=0xFEFE) vol=0xFEFE;
                       else VS1003B_WriteCMD(0x0b,vol);
                 else if(!(PIND&UP) && keylen==0) //ÒôÁ¿+           //Volume up
                     Delay(100);
                     if(!(PIND&UP))
                     keylen=200;
                       vol=vol-((uint16)(1<<8)+1);
                       if(vol<=0x0101) vol=0x0101;
                 else if(!(PIND&NEXT)) //ÏÂÒ»Ê×                       next songs
                    Delay(0x7fff);
                    if(!(PIND&NEXT))
                        Delay(0x7fff);
                        if(!(PIND&NEXT))
                            while(!(PIND&NEXT));
                            songs++;
                            if(songs > totalsongs)songs=1;
                                free(buffer);
                            //  Delay(0xffff);
                                goto next;
                 else if(!(PIND&PREV)) //ÉÏÒ»Ê×                       previous songs
                    Delay(0x7fff);
                    if(!(PIND&PREV))
                        Delay(0x7fff);
                        if(!(PIND&PREV))
                            while(!(PIND&PREV));
                            if(songs == 1)songs=totalsongs;
                            else songs--;
                                free(buffer);
                            //  Delay(0xffff);
                                goto next;
                 else if((!(PIND&MODE)) && keylen==0) //ģʽ            //mode key
                    Delay(100);
                    if(!(PIND&MODE))
                        keylen=0xffff;
                        if(mode==REPET_ALL)
                            mode=REPET_ONE;
                            LED1_ON();
                            LED2_OFF();
                        else if(mode==REPET_ONE)//next mode is shuffle
                            mode=RANDOM;
                            LED1_OFF();
                            LED2_ON();
                            srandom(((uint32)TCNT1)<<16);//²úÉúËæ»úÊýµÄÖÖ×Ó
                        else
                            mode=REPET_ALL;
                            LED1_OFF();
                            LED2_OFF();
            sector++;
            free(buffer);
        i=0;
        p=FAT_NextCluster(p);//¶ÁÏÂÒ»´ØÊý¾Ý         //read next cluster
        if(p == 0x0fffffff || p == 0x0ffffff8 || (FAT32_Enable == 0 && p == 0xffff))//Èç¹ûÎÞºóÐø´ØÔò½áÊø£¬  //no more cluster
                if(mode==REPET_ALL)songs++;
                if(songs>totalsongs)songs=1;
                goto next;
//main function
int main()
    uint8 retry = 0;
    DDRD &= 0x03;//³õʼ»¯¶Ë¿Ú
    PORTD |= 0xfc;
    LED1_CON();
    LED1_OFF();
    LED2_CON();
    LED2_OFF();
    OSCCAL = 0x00;//×îСRCÕñµ´ÆµÂÊ  //in order to operate some low speed card the initialization should run at lowest speed
    Delay(0xffff);
    MMC_SD_Init();//³õʼ»¯spi¿Ú     //SPI initialize
    Delay(0xffff);
    if(VS1003B_Init())
        //LED1_ON();//ÅäÖÃVS1003    //config vs1003
        while(1)
            LED1_ON();
            Delay(0xffff);
            LED1_OFF();
            Delay(0xffff);
    Delay(0xffff);//Ìṩ×ã¹»µÄÑÓʱ                //supply enough delay
//  Delay(0xffff);
//  Delay(0xffff);
//  Delay(0xffff);
//  Delay(0xffff);
    while(MMC_SD_Reset())//³õʼ»¯SD¿¨                   //sd card initialize
        retry++;
        if(retry>20)
        //  LED2_ON();
            while(1)
                LED2_ON();
                Delay(0xffff);
                LED2_OFF();
                Delay(0xffff);
    OSCCAL = 0xff;//×î´óRCÕñµ´ÆµÂÊ              //normal operation maximum the frequency
    Delay(0xffff);                              //wait for stable
    if(FAT_Init())//³õʼ»¯Îļþϵͳ Ö§³ÖFAT16ºÍFAT32 //initialize file system  FAT16 and FAT32 are supported
    //  LED1_ON();
    //  LED2_ON();
    //  while(1);
        while(1)
            LED1_ON();LED2_ON();
            Delay(0xffff);
            LED1_OFF();LED2_OFF();
            Delay(0xffff);
#if FIX_DIRECTORY
    Search(PATH,&MusicInfo,&totalsongs,&type);//ËÑË÷¸ùĿϵĸèÇú ²»°üº¬×ÓĿ¼
#else
    SearchInit();
    Search(&MusicInfo,&totalsongs,&type);//ËÑË÷¸ùĿϵĸèÇú
#endif
    //Ò²¿ÉÒÔÖ¸¶¨Îļþ¼Ð ÈçSearch("\\new\\mp3",&MusicInfo,&totalsongs,&type);
    //´ú±íÔÚ¸ùĿ¼ÏµÄnewÎļþ¼ÐϵÄmp3ÎļþϵÄÒôÀÖÎļþ
    //search the songs in the root directery on the SD card
    //You can also specify the directery where the songs are placed
    //eg: Search("\\new\\mp3",&MusicInfo,&totalsongs,&type);
    //      means search the file in the foler C:\new\mp3
    PlayMusic();//²¥·Å¸èÇú      //play songs
    while(1)
        while(1)
            LED1_ON();LED2_OFF();
            Delay(0xffff);
            LED2_ON();LED1_OFF();
            Delay(0xffff);
    return 0;
