xpress_embedo
Hello!! Everyone...
Please tell me how to use Microchip Framework for my use....
Few months back i tried it for USB Framework and it doesn't work and now for MDD Framework..
This not works also..
Please tell me how to use it...
I just open a project based on PIC18F8722 uC and then save project as SD_CARD_Project
I compile it and it works fine..
Now i don't know where to write code...
I am confused.. i create a new file first.c and write a simple program in it..
Then i compiler it.. i got this error...
Please help me...
I don;t know how to use this..
#include <p18f8722.h>
#include <FSIO.h>
#pragma config WDT = OFF, OSC = HSPLL, LVP = OFF
#pragma config MCLRE = ON, CCP2MX = PORTC, MODE = MC
/* =================== START OF MAIN PROGRAM =================== */
// Start of MAIN Program
void main(void)
// Initialize the SD card routines
FSInit( );
// Other code here
Release build of project `C:\Microchip Solutions v2011-12-05\MDD File System-SD Card\SD_CARD_PROJECTS.mcp' started.
Language tool versions: MPASMWIN.exe v5.43, mplink.exe v4.40, mcc18.exe v3.40, mplib.exe v9.80
Fri Jun 15 16:58:12 2012
Clean: Deleting intermediary and output files.
Clean: Deleted file "C:\Microchip Solutions v2011-12-05\MDD File System-SD Card\Object - MDD File System-SD Card\FSIO.o".
Clean: Deleted file "C:\Microchip Solutions v2011-12-05\MDD File System-SD Card\Object - MDD File System-SD Card\SD-SPI.o".
Clean: Deleted file "C:\Microchip Solutions v2011-12-05\MDD File System-SD Card\Object - MDD File System-SD Card\salloc.o".
Clean: Deleted file "C:\Microchip Solutions v2011-12-05\MDD File System-SD Card\Object - MDD File System-SD Card\Demonstration.o".
Clean: Deleted file "C:\MDD File System-SD Card\Object - MDD File System-SD Card\First.o".
Clean: Done.
Executing: "C:\Program Files\Microchip\mplabc18\v3.40\bin\mcc18.exe" -p=18F8722 /i"..\Microchip\Include\PIC18 salloc" -I"..\Include\PIC18 salloc" -I"." -I".\PIC18F" -I"..\Include" -I"..\Include\MDD File System" -I"..\Microchip\Include" -I"..\..\Microchip\Include" -I"..\Microchip\Include\MDD File System" -I"..\..\Microchip\Include\MDD File System" -I"..\..\MDD File System-SD Card" -I"..\..\MDD File System-SD Card\PIC18F" "FSIO.c" -fo="..\..\MDD File System-SD Card\Object - MDD File System-SD Card\FSIO.o" -mL -Ls -O-
Executing: "C:\Program Files\Microchip\mplabc18\v3.40\bin\mcc18.exe" -p=18F8722 /i"..\Microchip\Include\PIC18 salloc" -I"..\Include\PIC18 salloc" -I"." -I".\PIC18F" -I"..\Include" -I"..\Include\MDD File System" -I"..\Microchip\Include" -I"..\..\Microchip\Include" -I"..\Microchip\Include\MDD File System" -I"..\..\Microchip\Include\MDD File System" -I"..\..\MDD File System-SD Card" -I"..\..\MDD File System-SD Card\PIC18F" "SD-SPI.c" -fo="..\..\MDD File System-SD Card\Object - MDD File System-SD Card\SD-SPI.o" -mL -Ls -O-
Executing: "C:\Program Files\Microchip\mplabc18\v3.40\bin\mcc18.exe" -p=18F8722 /i"..\Microchip\Include\PIC18 salloc" -I"..\Include\PIC18 salloc" -I"." -I".\PIC18F" -I"..\Include" -I"..\Include\MDD File System" -I"..\Microchip\Include" -I"..\..\Microchip\Include" -I"..\Microchip\Include\MDD File System" -I"..\..\Microchip\Include\MDD File System" -I"..\..\MDD File System-SD Card" -I"..\..\MDD File System-SD Card\PIC18F" "salloc.c" -fo="..\..\MDD File System-SD Card\Object - MDD File System-SD Card\salloc.o" -mL -Ls -O-
Executing: "C:\Program Files\Microchip\mplabc18\v3.40\bin\mcc18.exe" -p=18F8722 /i"..\Microchip\Include\PIC18 salloc" -I"..\Include\PIC18 salloc" -I"." -I".\PIC18F" -I"..\Include" -I"..\Include\MDD File System" -I"..\Microchip\Include" -I"..\..\Microchip\Include" -I"..\Microchip\Include\MDD File System" -I"..\..\Microchip\Include\MDD File System" -I"..\..\MDD File System-SD Card" -I"..\..\MDD File System-SD Card\PIC18F" "Demonstration.c" -fo="..\..\MDD File System-SD Card\Object - MDD File System-SD Card\Demonstration.o" -mL -Ls -O-
Executing: "C:\Program Files\Microchip\mplabc18\v3.40\bin\mcc18.exe" -p=18F8722 /i"..\Microchip\Include\PIC18 salloc" -I"..\Include\PIC18 salloc" -I"." -I".\PIC18F" -I"..\Include" -I"..\Include\MDD File System" -I"..\Microchip\Include" -I"..\..\Microchip\Include" -I"..\Microchip\Include\MDD File System" -I"..\..\Microchip\Include\MDD File System" -I"..\..\MDD File System-SD Card" -I"..\..\MDD File System-SD Card\PIC18F" "First.c" -fo="..\..\MDD File System-SD Card\Object - MDD File System-SD Card\First.o" -mL -Ls -O-
C:\Microchip Solutions v2011-12-05\MDD File System-SD Card\First.c:18:Warning [2052] unexpected return value
Executing: "C:\Program Files\Microchip\mplabc18\v3.40\bin\mplink.exe" /p18F8722 "PIC18F\18f8722_g.lkr" "Object - MDD File System-SD Card\FSIO.o" "Object - MDD File System-SD Card\SD-SPI.o" "Object - MDD File System-SD Card\salloc.o" "Object - MDD File System-SD Card\Demonstration.o" "..\..\MDD File System-SD Card\Object - MDD File System-SD Card\First.o" /u_CRUNTIME /z__MPLAB_BUILD=1 /m"SD_CARD_PROJECTS.map" /w /o"SD_CARD_PROJECTS.cof"
MPLINK 4.40, Linker
Device Database Version 1.3
Copyright (c) 1998-2011 Microchip Technology Inc.
Error - Configuration settings have been specified for address 0x00300001 in more than one object module. Found in '..\..\MDD File System-SD Card\Object - MDD File System-SD Card\First.o', previously found in 'Object - MDD File System-SD Card\Demonstration.o'
Errors : 1
Link step failed.
Release build of project `C:\Microchip Solutions v2011-12-05\MDD File System-SD Card\SD_CARD_PROJECTS.mcp' failed.
Fri Jun 15 16:58:20 2012
BUILD FAILED
Please help me...
