djape
Newbie level 5
- Joined
- Feb 8, 2013
- Messages
- 10
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,367
Hi everyone,
I am trying to get stabille em field in inductor so what i need is inductor and some current source to drive that inductor.The inductor is wounded and have cca 2000 turns, which in this case isn`t so important.
Problem i have in this case is with current source.I need stabile and constant current source, so i used lt3092-programmabile cs which is capable to produce up to 200mA. Several of them connected parallel will produce, or should produce larger current equal to summary of current each of them produce.And that is what is this "thing" doing. But during in time, after several moments current which LT3092 is producing suddenly starts to drop.It is not constant any more and also magnetic field in inductor also drops.I have tried to substitute inductive resistance with equivalent resistor and the same thing is happening.
I have several of lt3092 and tried them on external board.On the start current they produce is stabile and gets rapidly low after several moments.I used two resistor configuration to set desirable current, which is available in datasheet.Current each of them produce is 180mA.
Does anyone have some idea about this or from yours experience with this ic`s?
Thanks
Thanks
