vmware lmgrd is not running
Hi there,
I have recently installed SatLab on open suse 11.1 virtually with VMWARE Workstation (trial) on a Win XP Pro 32bit system. When I try to install the license following the user manuall instructions I get this message:
"linux-tvc9:/usr/local/bin # /usr/local/bin/sllminst ./licenseA.dat
Server license installation ...
Copy the license file
Stop a running server
lmutil - Copyright (c) 1989-2003 by Macrovision Corporation. All rights reserved.
Shutdown failed: Cannot connect to license server (-15,570:111 "Connection refused")
done - log from /usr/local/SatLab/log/lmgrd.log follows:
Start the server again
./lmgrd: relocation error: ./lmgrd: symbol errno, version GLIBC_2.0 not definedin file libc.so.6 with link time reference
cat: /usr/local/SatLab/S99satlab.tmpl: No such file or directory"
And when I try to run the program I get "
"linux-tvc9:/usr/local/bin # satlab
Checkout failed: Cannot connect to license server
The server (lmgrd) has not been started yet, or
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Feature: SATLAB
Server name: linux-tvc9
License path: /usr/local/SatLab/license.dat
FLEXlm error: -15,570. System Error: 111 "Connection refused"
For further information, refer to the FLEXlm End User Manual,
available at "www.macrovision.com"."
What worries me is the "...cannot connect to license server..." response. I have installed the cd of open suse (700Mb) not the dvd and only that; nothing else.
Can anybody give hints or suggestions?
Thank you in advance.
