Problem with Internal EEPROM data accessing of Atmega8
hardik.patel
Member level 5
Member level 5
I am trying to wireless device control using atmega8 n i need to store status of all device status on every update in internal EEPROM.
If i remove part of EEPROM then the manual control of device is perfect...device is toggling. But i need to add facility of EEPROM, so status before power off, will be as it is after power on again.
Somehow, The status is not saved in EEPROM.
Cant understand wheather that writing problem or reading problem...
Compiler - AVR GCC
Xtal- 7.3728Mhz
#include <avr/io.h>
#include <inttypes.h>
#include <util/delay.h>
#include<util/delay.h>
#include "eeprom.h"
#include "eeprom.c"
#define tbi(x,y) x ^= _BV(y) //toggle bit - using bitwise XOR operator
char data;
char a,b,c,d,e,f=0;
void USARTInit(uint16_t ubrr_value)
   UBRRL = ubrr_value;
   UBRRH = (ubrr_value>>8);
   UCSRC=(1<<URSEL)|(3<<UCSZ0);
   UCSRB=(1<<RXEN)|(1<<TXEN);
char USARTReadChar()
  while(!(UCSRA & (1<<RXC)))
      //Do nothing
   return UDR;
void USARTWriteChar(char data)
   while(!(UCSRA & (1<<UDRE)))
      //Do nothing
  UDR=data;
void b4_power()
	PORTC=EEPROMRead(0);
	PORTC=EEPROMRead(2);
	PORTC=EEPROMRead(3);
	PORTC=EEPROMRead(4);
	PORTC=EEPROMRead(5);
	PORTB=EEPROMRead(6);
	PORTB=EEPROMRead(7);
	PORTB=EEPROMRead(8);
void compare()
		int flag=0;
		int d0,d1,d2,d3,d4,d5,d6,d7,d8;
		b4_power();
	while(1)
		data=USARTReadChar(); a=data; USARTWriteChar(a);//_delay_ms(5);
		data=USARTReadChar(); b=data; USARTWriteChar(b);//_delay_ms(5);
		data=USARTReadChar(); c=data; USARTWriteChar(c);//_delay_ms(5);
		data=USARTReadChar(); d=data; USARTWriteChar(d);//_delay_ms(5);
		data=USARTReadChar(); e=data; USARTWriteChar(e);//_delay_ms(5);
		    if((a=='8') && (flag==0))
					flag=1;
			  if((b=='0') && (flag==1))
				flag=2;
			 if((c=='2') && (flag==2))
				flag=3;
			 if((d=='1') && (flag==3))
				flag=4;//PORTC=0x01;
			 if((flag==4) && (e=='A'))
						tbi(PORTC,PC0);  //here the toggling takes place
						d0 = bit_is_set(PINC,0); //status of PC0 wheather CLEARED/SET is stored in d0
									EEPROMWrite(0,d0); // That status of d0 will be store at 0th EEPROM Location
				 if((flag==4) && (e=='B'))
						tbi(PORTC,PC1);
						d1 = bit_is_set(PINC,1);
									EEPROMWrite(2,d1);
				 if((flag==4) && (e=='C'))
						 tbi(PORTC,PC2);
						 d2 = bit_is_set(PINC,2);
									EEPROMWrite(3,d2);
				 if((flag==4) && (e=='D'))
						 tbi(PORTC,PC3);
						 d3 = bit_is_set(PINC,3);
									EEPROMWrite(4,d3);
				 if((flag==4) && (e=='E'))
						 tbi(PORTC,PC4);
						 d4 = bit_is_set(PINC,4);
									EEPROMWrite(5,d4);
				 if((flag==4) && (e=='F'))
						 tbi(PORTC,PC5);
						 d5 = bit_is_set(PINC,5);
									EEPROMWrite(6,d5);
				 if((flag==4) && (e=='G'))
						 tbi(PORTB,PB0);
						 d6 = bit_is_set(PINB,0);
									EEPROMWrite(7,d6);
				 if((flag==4) && (e=='H'))
						 tbi(PORTB,PB1);
						 d7 = bit_is_set(PINB,1);
									EEPROMWrite(8,d7);
				 if((flag==4) && (e=='I'))
						 tbi(PORTB,PB2);
						 d8 = bit_is_set(PINB,2);
									EEPROMWrite(8,d8);
void main()
   USARTInit(47);    //UBRR = 51
    DDRC=0xFF;
	DDRD=0x00; // For RXD input
	DDRB=0xFF;
	//PORTB=0x00; //For Leds
	EEPROMWrite(0,0xFF);
PORTC=0b111111;PORTB=0xFF; _delay_ms(400); PORTC=0b000000;PORTB=0x00;
   //Loop forever
while(1)
	//b4_power();	//delay_ms(400);
	//PORTC=0x00;
	compare();
	//flag=0;a,b,c,d,e,f=0;
	//data=USARTReadChar();
	//USARTWriteChar(data);//while(1);
   //while(1)
		////DDRC=0xFF;
   //     //PORTC=0x00;   _delay_ms(150);  PORTC=0xFF;
		////Read data
   //   //USARTWriteChar('{');
   //   USARTWriteChar(data);
   //   //USARTWriteChar('}');
************************eeprom.c*************
#include <avr/io.h>
#include "eeprom.h"
uint8_t EEPROMRead(uint16_t uiAddress)
	/* Wait for completion of previous write */
	while(EECR & (1<<EEWE));
	/* Set up address register */
	EEAR = uiAddress;
	/* Start eeprom read by writing EERE */
	EECR |= (1<<EERE);
	/* Return data from data register */
	return EEDR;
void EEPROMWrite(uint16_t uiAddress, uint8_t ucData)
	/* Set up address and data registers */
	EEAR = uiAddress;
	EEDR = ucData;
	/* Write logical one to EEMWE */
	EECR |= (1<<EEMWE);
	/* Start eeprom write by setting EEWE */
	EECR |= (1<<EEWE);
****************eeprom.h***********
#ifndef EEPROM_H
#define EEPROM_H
void 	EEPROMWrite(uint16_t uiAddress, uint8_t ucData);
uint8_t	EEPROMRead(uint16_t uiAddress);
#endif
Both files are in above code..see at bottom side.
N btw i had solved this problem.
