Problem with inout in verilog for my program
Damomeera
Junior Member level 3
Coimbatore
Code Verilog - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
module REG_BANK(M_O,A_IO,SEL,A_EN,M_EN,RW,CLOCK
    output [7:0] M_O;
     inout [7:0] A_IO;
     input [2:0] SEL;
    input A_EN, M_EN, RW, CLOCK;
     reg [7:0] M_O, A_I;
     reg [7:0] memblk [0:7];
     assign A_IO = ( A_EN == 1'b1 && RW == 1'b0 )? A_I : A_IO;  // NOT WORKING NOT UPDATING THE A_IO VALUE
     always @( posedge CLOCK )
     begin
              if( M_EN == 1'b0 )
                    M_O = 8'b00000000;
              else if( M_EN == 1'b1 && RW == 1'b0 )
           begin
                    case ( SEL )
                      3'b000 : M_O = memblk[0];
                      3'b001 : M_O = memblk[1];
                      3'b010 : M_O = memblk[2];
                      3'b011 : M_O = memblk[3];
                      3'b100 : M_O = memblk[4];
                      3'b101 : M_O = memblk[5];
                      3'b110 : M_O = memblk[6];
                      3'b111 : M_O = memblk[7];
                      endcase
           end
           if( A_EN == 1'b0 )
           begin
              end
           else if( A_EN == 1'b1 && RW == 1'b0 )
           begin
                    case ( SEL )
                      3'b000 : A_I = memblk[0];
                      3'b001 : A_I = memblk[1];
                      3'b010 : A_I = memblk[2];
                      3'b011 : A_I = memblk[3];
                      3'b100 : A_I = memblk[4];
                      3'b101 : A_I = memblk[5];
                      3'b110 : A_I = memblk[6];
                      3'b111 : A_I = memblk[7];
                      endcase
           end
              else if( A_EN == 1'b1 && RW == 1'b1 )
           begin
                    case ( SEL )
                      3'b000 : memblk[0] = A_IO;
                      3'b001 : memblk[1] = A_IO;
                      3'b010 : memblk[2] = A_IO;
                      3'b011 : memblk[3] = A_IO;
                      3'b100 : memblk[4] = A_IO;
                      3'b101 : memblk[5] = A_IO;
                      3'b110 : memblk[6] = A_IO;
                      3'b111 : memblk[7] = A_IO;
                      endcase
           end
    end
endmodule
In the above program the A_IO value doesn't get updated during A_EN = 1 and RW = 0.
Pls help me.
There is no problem in reading the inout port.
I didn't get new values according to the assign statements :)
An inout port must be driven to z state if you want to read it as an input.
This is the output i got. pls help me sir.
Check out this thread for help with the inout port.
https://www.edaboard.com/threads/313198/
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
module TOP;
wire [7:0] m_o;
wire [7:0] a_io;
reg [7:0] a_i;
reg [2:0] sel;
reg a_en, m_en, rw, clk;
REG_BANK r ( m_o, a_i0, sel, a_en, m_en, rw, clk );
initial
begin
a_en = 1'b0;m_en = 1'b0;
#20 a_en = 1'b1; rw = 1'b1; sel = 3'b000; a_i = 8'b00101011;
#20 a_en = 1'b1; rw = 1'b1; sel = 3'b001; a_i = 8'b00101100;
#20 a_en = 1'b1; rw = 1'b1; sel = 3'b010; a_i = 8'b10000111;
#20 a_en = 1'b1; rw = 1'b1; sel = 3'b011; a_i = 8'b10101101;
#20 a_en = 1'b1; rw = 1'b1; sel = 3'b100; a_i = 8'b11111001;
#20 a_en = 1'b1; rw = 1'b1; sel = 3'b101; a_i = 8'b10101111;
#20 a_en = 1'b1; rw = 1'b1; sel = 3'b110; a_i = 8'b10000111;
#20 a_en = 1'b1; rw = 1'b1; sel = 3'b111; a_i = 8'b10100111;
#20 rw = 1'b0; sel = 3'b010; a_en = 1'b1;
#20 a_en = 1'b0; m_en = 1'b1; sel = 3'b011;
end
initial
begin
#400 $finish;
end
initial
begin
clk = 1'b0;
forever #20 clk = ~ clk;
end
endmodule
it's stimulus module for the above module.
how to assign values to inout port
Sorry Bro
I want to design a register bank with one inout port and one output port.
If you are using an inout then this register bank better be interfacing with an external device as inout can only be represented by a bidirectional I/O pin.
If it's an internal signal you shouldn't be using inout.
Regards
