Re: Current bias (urgent)
that i bias circuit you can use either internal current or external current. for internal current you need to design the current sink circuit. for external current, you can supply the current externally with very precise resistor. however you need to select what value of current to drive the circuit. it is all depend on your characteristic of opamp that you desired. if you want really high gain, you can use high current because gain=gmro, gm is the transconductance of circuit while ro is the output impedance.
one more thing, you need to assure all the transistor operate in active region. i suspect your dc biasing might be wrong.
