[SOLVED] problem with IAR code
Mr.eyni
Newbie level 5
Hello
I wrote a program in IAR. The program has an error when executing the following line.
UART1_SendData8("A");
The complete program file is available below.
I would be grateful if you could tell me the mistakes of my code.
--- Updated ---
Hello
it is very short code and the error occurs in the last line
and microcontroller modell is STM8S003F3
--- Updated ---
this is the code and error is in line 52
--- Updated ---
#include "stm8s.h"
#include "stm8s_gpio.c"
#include "stm8s_uart1.h"
#include "stm8s_uart1.c"
#include "stm8s_clk.h"
#include "stm8s_gpio.h"
#include "stm8s_conf.h"
#include "stm8s_clk.c"
void Clk_Config(void){
  CLK_DeInit();
  CLK_HSECmd(ENABLE);
  CLK_ClockSwitchConfig(CLK_SWITCHMODE_AUTO,CLK_SOURCE_HSE,DISABLE,CLK_CURRENTCLOCKSTATE_DISABLE);
  CLK_SYSCLKConfig(CLK_PRESCALER_CPUDIV1);
  CLK_ClockSecuritySystemEnable();
  CLK_PeripheralClockConfig(CLK_PERIPHERAL_UART1,ENABLE);
void UART1_setup(void)
     UART1_DeInit();
     UART1_Init(9600,
                UART1_WORDLENGTH_8D,
                UART1_STOPBITS_1,
                UART1_PARITY_NO,
                UART1_SYNCMODE_CLOCK_DISABLE,
                UART1_MODE_TXRX_ENABLE);
                UART1_Cmd(ENABLE);
                UART1_ITConfig(UART1_IT_RXNE_OR, ENABLE);
int main( void )
         char var;
         Clk_Config();
         UART1_setup();
         GPIO_DeInit(GPIOD);
         GPIO_Init(GPIOD, GPIO_PIN_5, GPIO_MODE_OUT_PP_HIGH_FAST);
         GPIO_Init(GPIOD, GPIO_PIN_6, GPIO_MODE_IN_PU_NO_IT);
         enableInterrupts();
         var = UART1_ReceiveData8();
  • 2.zip
Is it a guessing game? You don't even mention the error message.
Also, why are declaring .rar files as .zip?
I guess, it's a simple fault. UART1_SendData8() is expecting uint8 argument, "A" is a string, you probably want to write 'A' instead.
thanks for your help. the problem solved.
