King-Pago
Newbie level 3
I'm trying to get my pic to send the words "YES" & "NO" to the communication window that appears when you're running Hyperterminal . There's nothing specifically wrong with my code, I've echoed the words I'd like to send back to my RX pin on the chip and it reflects that they're recieved. But when I try using Hyperterminal to display the above (I'm using a USB-serial port cable(DB9)), nothing appears. I've set the correct Baud Rate and all.
I just noticed something just now, when I was playing around with the pin 2 on the USB-serial Port cable, I had a copper line coming from my MAX232 chip and I kept brushing it up and down against pin 2(my transmission pin), the hyperterminal window responds, it prints the words above but they come out with a host of characters undesirable.For instance I see things like:
&*&^%%#$#YES%%$#@+_)(&NO******-+/... and so on
and when I do not rub it against pin2 and just simply leave them in contact, nothing happens.
why is it doing this?Has anybody ever experienced the same problem and how did they go about fixing it. Much appreciation for any help. One Love.
