rodian
Newbie level 3
Hi all,
I simulate a clock oscillator with hspice using a priopretary MOSFET model (.option scale=0.12u) . The weird thing is that in Hspice X-2005.09 under Windows 7 there is no problem at all.
However, when I try to simulate the exactly same netlist in Hspice A-2008.03-SP1 under Linux I get the message:
**error** reference 0:nfet not found, or instance width or length does not fit into the wmax/wmin or lmax/lmin range.
it was referenced in element 1:m1
the channel width= 3.600E-06 and length= 1.200E-06
the line number was 40
I have also tried another circuit in both systems (a transmission line) to check if the problem is a global one, but the 2nd simulation works fine in both systems. So, I guess the problem is not related to the operating systems nor to the different Hspice versions I'm using.
Any ideas???
Any ideas???
