problem with header files and processors (redefined error)
sairfan1
Full Member level 1
Regina, Canada
I'm having problem while working in MikroC, i want to break my code into library, see how can i make following code workable.
//file test.h
#ifndef _TEST_H_
 #define _TEST_H_
#define __TEST_DEF 1
unsigned char __chr = 'D';
void set_char(unsigned char c);
unsigned get_char(void);
unsigned do_access();
#endif
// file test.c
#include "test.h"
#include "access.h"
void set_char(unsigned char c){
  if (__chr == __TEST_DEF)
   __chr = 'T';
  else
   __chr = c;
unsigned get_char(void){
 return __chr;
unsigned do_access(){
 return acc;
//file access.h
#ifndef _ACCESS_H_
 #define __ACCESS_H_
unsigned char acc = 'S';
void setchar(unsigned char c);
unsigned getchar(void);
unsigned char do_test();
#endif
// file access.c
// accessing sourcing of other header and c files
// variables, functions and #define macros
#include "test.h"
#include "access.h"
void setchar(unsigned char c){
   __chr = 'T';
  else
   __chr = c;
unsigned getchar(void){
 return __chr;
unsigned char do_test(){
 returne get_char();
// file main.c
#include "test.h"
#include "access.h"
void main(void){
 TRISB = 0;
 PORTB = 0;
 setchar('B');
 PORTB = get_char();
 Delay_ms(1500);
 set_char('A');
 PORTB = getchar();
 Delay_ms(1500);
 PORTB = do_test();
 Delay_ms(1500);
 PORTB = do_access();
 Delay_ms(1500);
 while(1);
in test.h
defines the variable __chr (in effect allocating storage for it)
if you include test.h in more than one .c file your with multiply definition or similar errors
in test.h declare it extern (in effect saying this variable is defined elsewhere in the project)
extern unsigned char __chr = 'D';
and in test.c define it
you only have one definition in the project and many .c can include the declaration as required
still having problem, lets make this example simple for a while. following is the simplified code. Please also advise what is the sequence of compiler to link these files, this could also help to understand. thanks
//file test.h
#ifndef _TEST_H_
 #define _TEST_H_
#endif
// file test.c
#include "test.h"
   __chr = 'T';
  else
   __chr = c;
 return __chr;
// file main.c
#ifndef __INCLUDES
 #define __INCLUDES
#include "test.h"
#endif
void main(void){
 TRISB = 0;
 PORTB = 0;
 set_char('A');
 PORTB = get_char();
 Delay_ms(1500);
 while(1);
put the declaration (using extern) of __chr in the test.h file and the definition (where memory is allocated) in the test.c file, e.g.
//file test.h
#ifndef _TEST_H_
 #define _TEST_H_
extern unsigned char __chr;
#endif
// file test.c
#include "test.h"
   __chr = 'T';
  else
   __chr = c;
 return __chr;
// file main.c
#ifndef __INCLUDES
 #define __INCLUDES
#include "test.h"
#endif
void main(void){
 TRISB = 0;
 PORTB = 0;
 set_char('A');
 PORTB = get_char();
 Delay_ms(1500);
 while(1);
Now I'm getting error message.
13 324 Undeclared identifier '__TEST_DEF' in expression test.c
it looks like you have removed the
#include "test.h"
in test.c? you still need it for __TEST_DEF
Did you check every line for syntax or spelling errors?
there is not spelling mistakes, i guess while posting i made some mistake.
#include "test.h"
if add #include "test.h" line to test.c file error message is
redefined __chr
redefined __chr
have you left the initialisation of __chr in the extern declaration in test.h?
you should not initialize an extern (some compilers ignore it, others treat it has a definition and give various errors)- it should be a simple declaration
you should only initialise in a definition - it is initialized in the test.c file in your case
thanks, at last i over come the problem, now only two things left.
1) below macro is defined in test.c file and accessible, but it is not accessible from main function.
2) i added more code to main.c file to control the buttons, BTN7 is not being accessed by test.c file.
sbit BTN7 at RB7_bit;
sbit BTN6 at RB6_bit;
sbit BTN5 at RB5_bit;
sbit BTN4 at RB4_bit;
Try crank you code such as double #include<> and redefined commands more as possible .
