Hi
I am facing problem with floating point 5.0v core generator.
I want convert float to fix and my configuration is:
floating-point precision : single (32bit)
fix-point precision :int32(32bit)
my code is:
HTML:
module top(x);
reg clk;
output [31:0] x;
real a;
initial
begin
clk=1'b0;
forever #30 clk=~clk;
#600 $stop;
end
initial
begin
a=0.9
end
float f2 (
.a(a), // input [31 : 0] a
.clk(clk), // input clk
.result(x) // output [31 : 0] result
endmodule
what exist ways for convert real to ieee754?
for example i have float number=0.9 , how i must to define my float number which i to be able use IEEE754?
Real is an abstract data format only used in simulation and for parameters and constants calculated at synthesis time.
Conversion function to_float() from real to float is e.g. provided in IEEE float package. I'm not familiar with Xilinx tools and float IP, I don't know if they provide specific conversion functions for constants, but IEEE package should do the trick.
