Mohammad Zubair
Junior Member level 3
I was testing my dspic30f3010 with a test code i got from internet. I used cheap clone Pickit 2 to program my IC. My IC was working very fine. However, when I tried imporing the actual code, my both ICs became unresponsive.
the problem I detected from searching the internet was I have disabled the MCLR pin in my test program.
The solution to it I found on net was possible with the original pickit 2. As cheap pickit 2 does not have Vdd control circuit.
Now What should I be doing to resurrect these ICs:
1) Use a pickit3 from microchip (oriinal) as it will (I suppose) be having the Vdd control circuit required for its solution. We do not have pickit 2 original available in our country.
2) Design an additional circuitry for the cheap pickit 2 which will give the required results.
Please Do guide me!!! It's urgent!!!!
#include <p30f3010.h>
// Configuration settings
_FOSC(CSW_FSCM_OFF & FRC_PLL16); // Fosc=16x7.5MHz, Fcy=30MHz
_FWDT(WDT_OFF); // Watchdog timer off
_FBORPOR(MCLR_DIS); // Disable reset pin
int main()
// Configure all four port D pins (RD0, RD1, RD2, RD3)
// as digital outputs
LATD = 0;
TRISD = 0b1111111111110000;
// Flash LEDs on RD0 and RD1 at 1Hz for 4 seconds
while(1)
_LATD0 = 0;
__delay32(15000000);
_LATD0 = 1;
return 0;
