# include<reg51.h>
sbit dq = P3^5; // connect with DS1820 Data pin
sbit rs=P3^0;
sbit en=P3^1;
void delay_ms(int j)
unsigned char i;
for(;j;j--)
for(i=122;i<=0;i--);
void delayus(int us)
int i;
for (i=0; i<us; i++);
bit reset(void)
bit presence;
dq = 0;
delayus(29);
dq = 1;
delayus(3);
presence = dq;
delayus(25);
return(presence);
bit readbit(void)
unsigned char i=0;
dq = 0;
dq=1;
for (i=0; i < 3; i++);
return(dq);
void writebit(bit Dbit)
unsigned char i=0;
dq=0;
dq = Dbit?1:0;
delayus(5);
dq = 1;
unsigned char readbyte(void)
unsigned char i;
unsigned char din = 0;
for (i=0;i<8;i++)
din|=readbit()? 0x01<<i:din;
delayus(6);
return(din);
void writebyte(unsigned char dout)
unsigned char i;
for (i=0; i<8; i++)
writebit((bit)(dout & 0x1));
dout = dout >> 1;
delayus(5);
unsigned char * ReadTemp()
unsigned char n;
unsigned char buff[2]=0;
reset();
writebyte(0xcc);
writebyte(0x44);
while (readbyte()==0xff);
delay_ms(500);
reset();
writebyte(0xcc);
writebyte(0xbe);
for (n=0; n<9; n++)
buff[n]=readbyte();
return buff;
void delay_ms110(unsigned int k)
unsigned int i,j;
for (i=0;i<=k;i++)
for(j=0;j<110;j++);
void Serial_TX(char *str)
unsigned int j;
TMOD=0x20;
TH1=0xFD;
SCON=0x50;
TR1=1;
for(j=0;str[j]!=0;j++)
SBUF=str[j];
while(TI==0)
TI=0;
delay_ms110(500);
void Serial_TX_temp(char tp)
unsigned int j;
TMOD=0x20;
TH1=0xFD;
SCON=0x50;
TR1=1;
SBUF=tp;
while(TI==0)
TI=0;
delay_ms110(500);
void main()
unsigned char tp,*temp,t=0x00;
while(1)
dq = 0;
temp=ReadTemp();
temp[1]=temp[1]&0x07;
tp=temp[0]>>4;
temp[1]=temp[1]<<4;
tp=tp+temp[1];
P1 = tp;
Serial_TX(" tempis: ");
Serial_TX_temp(tp);
#include <reg51.h>
#include <INTRINS.h>
unsigned char readdata[2];
sbit DQ=P2^0;
sbit MM=P1^0;
sbit NN=P1^1;
unsigned char bdata busyflag;
unsigned char datn,count;
unsigned char dat[9];
unsigned char word1[16]={" T= "};
#define FALSE 0
#define TRUE 1
#define PERIOD 10
unsigned char ROM[8]; // ROM Bit
unsigned char lastDiscrep = 0; // last discrepancy
unsigned char doneFlag = 0; // Done flag
unsigned char FoundROM[2][8]; // table of found ROM codes
unsigned char numROMs;
unsigned char dowcrc;
int time = 101;
int i,numDev;
int scratch[9];
unsigned char code dscrc_table[] = {
0, 94,188,226, 97, 63,221,131,194,156,126, 32,163,253, 31, 65,
157,195, 33,127,252,162, 64, 30, 95, 1,227,189, 62, 96,130,220,
35,125,159,193, 66, 28,254,160,225,191, 93, 3,128,222, 60, 98,
190,224, 2, 92,223,129, 99, 61,124, 34,192,158, 29, 67,161,255,
70, 24,250,164, 39,121,155,197,132,218, 56,102,229,187, 89, 7,
219,133,103, 57,186,228, 6, 88, 25, 71,165,251,120, 38,196,154,
101, 59,217,135, 4, 90,184,230,167,249, 27, 69,198,152,122, 36,
248,166, 68, 26,153,199, 37,123, 58,100,134,216, 91, 5,231,185,
140,210, 48,110,237,179, 81, 15, 78, 16,242,172, 47,113,147,205,
17, 79,173,243,112, 46,204,146,211,141,111, 49,178,236, 14, 80,
175,241, 19, 77,206,144,114, 44,109, 51,209,143, 12, 82,176,238,
50,108,142,208, 83, 13,239,177,240,174, 76, 18,145,207, 45,115,
202,148,118, 40,171,245, 23, 73, 8, 86,180,234,105, 55,213,139,
87, 9,235,181, 54,104,138,212,149,203, 41,119,244,170, 72, 22,
233,183, 85, 11,136,214, 52,106, 43,117,151,201, 74, 20,246,168,
116, 42,200,150, 21, 75,169,247,182,232, 10, 84,215,137,107, 53};
/////////////////end of variable////////////
void Serial_TX(char *str);
///////////////ds18b20/////////////////////
//Delay function
void delay(unsigned int i)
while(i--);
unsigned char i;
for(;j;j--)
void delay_us(int us)
int i;
// OW_RESET - performs a reset on the one-wire bus and
// returns the presence detect. Reset is 480us, so delay
// value is (480-24)/16 = 28.5 - we use 29. Presence checked
// another 70us later, so delay is (70-24)/16 = 2.875 - we use 3.
unsigned int ow_reset(void)
unsigned int presence;
DQ = 0; //pull DQ line low
delay_us(29); // leave it low for 480us
DQ = 1; // allow line to return high
delay_us(3); // wait for presence
presence = DQ; // get presence signal
delay_us(25); // wait for end of timeslot
return(presence); // presence signal returned
} // 0=presence, 1 = no part
//Initialization function
void Init_DS18B20(void)
unsigned char x=0;
DQ = 1; //DQ reset
delay(8); //Slight delay
DQ = 0; //SCM will be pulled down DQ
delay(80); //Accurate than 480us delay
DQ = 1; //Pulled the bus
delay(14);
x=DQ; //After slight delay is initialized if x = 0 x = 1 is initialized successfully defeat
delay(20);
//Reading a byte
unsigned char ReadOneChar(void)
unsigned char i=0;
unsigned char dat = 0;
for (i=8;i>0;i--)
DQ = 0; // To the pulse signal
dat>>=1;
DQ = 1; // To the pulse signal
if(DQ)
dat|=0x80;
delay(4);
return(dat);
// READ_BIT - reads a bit from the one-wire bus. The delay
// required for a read is 15us, so the DELAY routine won't work.
// We put our own delay function in this routine in the form of a
// for() loop.
unsigned char read_bit(void)
unsigned char i;
DQ = 0; // pull DQ low to start timeslot
DQ = 1; // then return high
for (i=0; i<3; i++); // delay 15us from start of timeslot
return(DQ); // return value of DQ line
void write_bit(char bitval)
if(bitval==1) DQ =1; // return DQ high if write 1
delay_us(5); // hold value for remainder of timeslot
DQ = 1;
}// Delay provides 16us per loop, plus 24us. Therefore delay(5) = 104us
//Write a byte
void WriteOneChar(unsigned char dat)
unsigned char i=0;
for (i=8; i>0; i--)
DQ = 0;
DQ = dat&0x01;
delay(5);
DQ = 1;
dat>>=1;
delay(4);
// ONE WIRE CRC
unsigned char ow_crc( unsigned char x)
dowcrc = dscrc_table[dowcrc^x];
return dowcrc;
// NEXT
// The Next function searches for the next device on the 1-Wire bus. If
// there are no more devices on the 1-Wire then false is returned.
unsigned char Next(void)
unsigned char m = 1; // ROM Bit index
unsigned char n = 0; // ROM Byte index
unsigned char k = 1; // bit mask
unsigned char x = 0;
unsigned char discrepMarker = 0; // discrepancy marker
unsigned char g; // Output bit
unsigned char nxt; // return value
int flag;
nxt = FALSE; // set the next flag to false
dowcrc = 0; // reset the dowcrc
flag = ow_reset(); // reset the 1-Wire
if(flag||doneFlag) // no parts -> return false
lastDiscrep = 0; // reset the search
return FALSE;
WriteOneChar(0xF0); // send SearchROM command
do
// for all eight bytes
x = 0;
if(read_bit()==1)
x = 2;
delay_us(6);
if(read_bit()==1)
x |= 1; // and its complement
if(x ==3) // there are no devices on the 1-Wire
break;
else
if(x>0) // all devices coupled have 0 or 1
g = x>>1; // bit write value for search
else
// if this discrepancy is before the last
// discrepancy on a previous Next then pick
// the same as last time
if(m<lastDiscrep)
g = ((ROM[n]&k)>0);
else // if equal to last pick 1
g = (m==lastDiscrep); // if not then pick 0
// if 0 was picked then record
// position with mask k
if (g==0) discrepMarker = m;
if(g==1) // isolate bit in ROM[n] with mask k
ROM[n] |= k;
else
ROM[n] &= ~k;
write_bit(g); // ROM search write
m++; // increment bit counter m
k = k<<1; // and shift the bit mask k
if(k==0) // if the mask is 0 then go to new ROM
{ // byte n and reset mask
ow_crc(ROM[n]); // accumulate the CRC
n++; k++;
}while(n<8); //loop until through all ROM bytes 0-7
if(m<65||dowcrc) // if search was unsuccessful then
lastDiscrep=0; // reset the last discrepancy to 0
else
// search was successful, so set lastDiscrep,
// lastOne, nxt
lastDiscrep = discrepMarker;
doneFlag = (lastDiscrep==0);
nxt = TRUE; // indicates search is not complete yet, more
// parts remain
return nxt;
// FIRST
// The First function resets the current state of a ROM search and calls
// Next to find the first device on the 1-Wire bus.
unsigned char First(void)
lastDiscrep = 0; // reset the rom search last discrepancy global
doneFlag = FALSE;
return Next();
// FIND DEVICES
int FindDevices(void)
unsigned char m;
int count = 0;
Serial_TX(" start of find");
if(!ow_reset()) //Begins when a presence is detected
Serial_TX(" ow_reset");
if(First()) //Begins when at least one part is found
numROMs=0;
do
numROMs++;
count++;
for(m=0;m<8;m++)
FoundROM[numROMs][m]=ROM[m]; //Identifies ROM
// number on found device
}while (Next());
else
Serial_TX(" else ow_reset");
return count;
void Read_ROMCode(void)
int n;
ow_reset();
WriteOneChar(0x33);
for (n=0;n<8;n++){dat[n]=ReadOneChar();}
// Perform Match ROM
unsigned char Send_MatchRom(void)
unsigned char i;
if(ow_reset()) return 0;
WriteOneChar(0x55); // match ROM
for(i=0;i<8;i++)
WriteOneChar(FoundROM[numROMs][i]); //send ROM code
return 1;
void Read_ScratchPad(void)
int j;
char pad[9];
WriteOneChar(0xBE);
for (j=0;j<9;j++)
pad[j]=ReadOneChar();
//Read temperature
void ReadTemperature(void)
Init_DS18B20();
WriteOneChar(0xCC); // Skip read serial number column number of operations
WriteOneChar(0x44); // Start temperature conversion
Init_DS18B20();
WriteOneChar(0xCC); //Skip read serial number column number of operations
WriteOneChar(0xBE); //Read the temperature register, etc. (a total of 9 registers readable) is the temperature of the first two
readdata[0]=ReadOneChar();
readdata[1]=ReadOneChar();
void Tempprocess() //Temperature Conversion
unsigned int t;
float tt;
unsigned char temp;
if((readdata[1]&0x80)!=0)
word1[3]='-';
t=readdata[1];
t<<=8;
t=t|readdata[0];
t=t-1;
t=~t;
t>>=4;
word1[4]=t/100+48;
word1[5]=((t/10)%10)+48;
word1[6]=t%10+48;
temp=readdata[0];
temp=temp-1;
temp=~temp;
temp=temp&0x0f;
tt=temp*0.0625;
word1[7]='.';
word1[8]=(unsigned char )(tt*10);
word1[9]=(unsigned char )(tt*100-word1[8]*10);
word1[10]=(unsigned char )(tt*1000-word1[8]*100-word1[9]*10);
word1[11]=(unsigned char )(tt*10000-word1[8]*1000-word1[9]*100-word1[10]*10);
word1[8]+=48;
word1[9]+=48;
word1[10]+=48;
word1[11]+=48;
word1[12]='C';
else
word1[3]='+';
t=readdata[1];
t<<=8;
t=t|readdata[0];
t>>=4;
word1[4]=t/100+48;
word1[6]=t%10+48;
temp=readdata[0];
temp=temp&0x0f;
tt=temp*0.0625;
word1[7]='.';
word1[8]+=48;
word1[9]+=48;
word1[10]+=48;
word1[11]+=48;
word1[12]='C';
/////////////////////end of ds18b20//////////////////
/////////////////////Serial//////////////////
unsigned int i,j;
for (i=0;i<=k;i++)
for(j=0;j<110;j++);
unsigned int j;
TMOD=0x20;
TH1=0xFD;
SCON=0x50;
TR1=1;
SBUF=str[j];
while(TI==0)
TI=0;
delay_ms110(500);
TMOD=0x20;
TH1=0xFD;
SCON=0x50;
TR1=1;
SBUF=tp;
while(TI==0)
TI=0;
delay_ms110(1500);
/////////////////////end of serial//////////////////
void main()
MM = 0;
NN = 1;
Init_DS18B20();
Serial_TX("start ");
// Find devices on the bus
numDev = FindDevices();
for(i=1; i<=numDev; i++)
Serial_TX("Device: ");
while(1)
if ((!ow_reset())) // If a device is present and it's time to send string
time = 0;
WriteOneChar(0xCC); // Skip Rom command
WriteOneChar(0x44); // Temperature convert command
DQ = 1;
delay_ms(750); // Max. conv. time is 750mS for 12 bit
ow_reset();
// read all devices on bus
for (numROMs=1; numROMs <= numDev; numROMs++)
if (Send_MatchRom())
WriteOneChar(0xBE); // Read scratch pad command
for(i=0; i<2; i++)
readdata[i]= ReadOneChar();
if(numROMs == 1)
Serial_TX(" Sensor #1: ");
Tempprocess();
Serial_TX(word1);
if(numROMs == 2)
Serial_TX(" Sensor #2: ");
Tempprocess();
Serial_TX(word1);
} // if (Send_MatchRom())
} // for (numRoms=1; numRoms <= numDev; numRoms++)
} // if ((!ow_reset())&&(time > PERIOD))
/* ReadTemperature();
Tempprocess();
P1 = (readdata[0]>>4);
Serial_TX(word1);
