Makatas
Newbie level 5
Good afternoon! This is my first post in here and I wish I get some help because I really need it.
I happen to own a rotary tool which is like the Dremel ones, but is not a Dremel. I am satisfied with how it works.
Two months ago I bought a second, because I want to ship it to a friend abroad. So, I got it, I opened the box and tried it, and when I saw that it works flawlessly, I put it back in its little plastic case, supporting it with bubbles etc.
Weeks later, the rotary tool arirved at its destinations, but it is not working properly. What it does:
At speeds 1,2 and 3 it barely turns. At 4,5 and max it turns but will sotp when it meets any kind of resistance. As you understand, it cannot do anything even to the softest things. It really stops and has no torque.
Me and my friend tried to troubleshoot it, she has some technical skills and I aided with mine. She checked the brushes, removed and put back in, then replaced with the back-up ones, it didnt work still. She opeend the case and checked for possible problems with the speed switch or anything, sitll the thing is brand new. It really hasnt worked at all, so I dont know what the problem could be.
Could you please give some suggestions on it?
Thank you all
Thank you all
