[SOLVED] problem with displaying message on the LCD
interrupt() routine is commented, I don't use it, because it doesn't work, so I chose to monitor the USART and to display the messages on the LCD inside the while(1) loop.
Hey,
Are you by any chance using a Powertip LCD?
i had a problem just like it a long long time ago.
Maybe you are just letting the LCD making the init/reset
These LCD take a long, long time to ini.
Just try to increase the times on the ini cycle
void LCDInit(void)
     Delay1KTCYx(240);
    LATA=0;
    LATC=0;
    //Outputs
    TRISAbits.TRISA7=0;        //RS signal
    TRISAbits.TRISA6=0;        //EN signal
    TRISCbits.TRISC0=0;        // RC0 output, DB4
    TRISCbits.TRISC1=0;        // RC1 output, DB5
    TRISCbits.TRISC2=0;        // RC2 output, DB6
    TRISCbits.TRISC3=0;        // RC3 output, DB7
    TRISCbits.TRISC5=0;        // STATUS LED
    TRISCbits.TRISC6=0;        // UART_TX
    //Inputs
    TRISBbits.TRISB4=1;        //data0
    TRISBbits.TRISB3=1;        //data1
    TRISCbits.TRISC4=1;        // button
    TRISCbits.TRISC7=1;        //UART_RX
    // Oscillator frequency
    OSCCON=0b01100111;        // 4MHz
    // pins configurred as digital
    ADCON1=0b00001111;
    // Interrupt config
    INTCON=0x40;                   // PEIE high
    IPR1bits.RCIP=1;                // EUSART Receive Interrupt High Priority
    RCONbits.IPEN=1;            // enable priority levels
    PIE1bits.RCIE=1;            // Enable EUSART receive interrupt
    LATAbits.LATA6=0;        // Set En on 0
    Delay1KTCYx(100);        //Delay 100ms
    LATAbits.LATA7=0;        // Set RS on 0
    Delay1KTCYx(240);        //Delay 15ms
    LATC=0x3;
    en_set();
    Delay1KTCYx(10);
    LATC=0x3;
    en_set();
    Delay1TCYx(10);
    LATC=0x3;
    en_set();
    Delay1TCYx(10);
    LATC=0x2;
    en_set();
    Delay1TCYx(10);
    //Function set
    cmd(0x28);            // 4 bits, 2 lines, 5x7 dots format display mode
    Delay1TCYx(10);        // delay 40us
    //Display ON control
    cmd(0x0E);            // display on, cursor on, blinking cursor position off
    Delay1TCYx(25);
    //Clear Display
    cmd(0x01);            // dispaly clear
    Delay1KTCYx(15);
    //Entry set increment
    cmd(0x06);            // increment, shift right
    Delay1KTCYx(20);
For example i did this some years ago
    ADCON1 = 0b1001110;
    init_value = 0x3;
//  TRISA=0;
    TRISD=0;
//  TRISB=0;
//  TRISC=0;
    __delay_ms(200);        // Powertip LCD needs a delay here to enable init
    LCD_RS = 0;
    LCD_EN = 0;
    LCD_RW = 0;
    __delay_ms(200);    // wait after power applied,
    LCD_DATA     = init_value;
Hope it helps.
hello,
What is your power supply for 18F26K20 and LCD
18F26K20 is 3,6V maximum
is your LCD compliant with this power voltage ?
if not , supply the LCD with 5V..
here is a LCD test
// programme de test du COG16 LCD 2x16
// test de la librairie XLCD_lite.h
// test avec oscil Quartz 10Mhz
// usage Msg en RAM,ROM,EEPROM
// nota :  test à 1MHz (si oscillateur interne) aussi OK..mais plus lent.
#define Versus      "Ver.130806 C18 "
#define Source      "18F26K20_Test_COG16_130806.c"
#define Projet      "18F26K20_LCD2x16.mcp"
#define Hardware    "18F26k20_COG16_LCD.txt"
#include <p18f26k20.h>
#include <../_common/LCD2x16_lite.h>
#include <stdio.h>         // sprintf
#include <stdlib.h>
#include <delays.h>
#include <string.h>
#include <usart.h>   // pour fonctions UART
#include <adc.h>
#include <ctype.h>
#include <portb.h>
#include <timers.h>
#include <math.h>
// HARDWARE
// Q=10Mhz
// ATTENTION alim 3,6V maxi
//1     MCLR 4,K +VSS
//2     RA0 Analog input
//3     RA1 Analog input
//4     RA2
//5     RA3
//6     RA4 Output Led rouge
//7     RA5
//8     +3,6V
//9     RA6  clockIN   Quartz 10Mhz 22pF
//10    RA7  clockOUT  Quartz 10Mhz 22pF
//11    RC0
//12    RC1
//13    RC2
//14    RC3
//28    RB7 Data D7 LCD
//27    RB6 Data D6 LCD
//26    RB5 Data D5 LCD
//25    RB4 Data D4 LCD
//24    RB3 En LCD
//23    RB2 RS LCD
//22    RB1
//21    RB0
//20    GND 0V
//19    VSS +3,6V
//18    RC7
//17    RC6
//16    RC5
//15    RC4
//#define OSCILLATEUR_INTERNE
#ifdef OSCILLATEUR_INTERNE
#pragma config FOSC = INTIO67, FCMEN = OFF            // CONFIG1H
#else
#pragma config FOSC = HS, IESO=OFF ,FCMEN=OFF, LPT1OSC=OFF
#endif
#pragma config PWRT=OFF,BOREN=OFF,WDTEN=OFF
#pragma config PBADEN=OFF,CCP2MX=PORTC
#pragma config MCLRE=ON,STVREN=OFF,LVP=OFF,XINST=OFF,DEBUG=OFF
#pragma config CP0 = OFF, CP1 = OFF, CP2 = OFF, CP3 = OFF                    // CONFIG5L
#pragma config CPB = OFF, CPD = OFF                                          // CONFIG5H
#pragma config WRT0 = OFF, WRT1 = OFF, WRT2 = OFF, WRT3 = OFF                // CONFIG6L
#pragma config WRTB = OFF, WRTC = OFF, WRTD = OFF                            // CONFIG6H
#pragma config EBTR0 = OFF, EBTR1 = OFF, EBTR2 = OFF, EBTR3 = OFF            // CONFIG7L
#pragma config EBTRB = OFF                                                   // CONFIG7H
rom const char chaine0[]="Frame Erreur et Overflow detection : ";
rom const char chaine1[]="Port comm ...... bds, ouvert \r\n";
rom const char chaine2[]="18F26K20_Test_COG16_130806.c \r\n";
rom const char chaine3[]="ESC pour sortir\r";
rom const char chaine4[]="J= ";
rom const char chaine5[]="COG16 versus C18";
rom const char chaine6[]="PIC18F26K20 3,3V";
rom const char chaine7[]="................ \r\n";
rom char *RS_Str[]={chaine0,chaine1,chaine2,chaine3,chaine4,chaine5 ,chaine6,chaine7   };
#pragma romdata EEP_=0xF00000
rom unsigned char EEPROM_data [][32] ={
      //   1234567890123456789012345678901
          "Proj.18F26K20_LCD2x16.mcp     \r",//0  avec terminateur zero
          Versus         "               \r",                           //20
          "Init Hardware et Comm.        \r",//40  avec terminateur zero
          "Boucle en 1 Sec   <ESC> exit  \r",//60  avec terminateur zero
          "Init BlueTooth                \r",//80  avec terminateur zero
          "paulfjujo@free.fr              \r",//A0   sans terminateur zero
          "MPLAB IDE V8.91                \r", //C0  sans terminateur zero
          "C18 v3.45.00                  \r", //E0
          "100                           \r",//100  avec terminateur zero
          "120                           \r",//100  avec terminateur zero
          "140                           \r",//100  avec terminateur zero
          "160                           \r",//100  avec terminateur zero
          "180                           \r",//100  avec terminateur zero
          "1A0                           \r",//100  avec terminateur zero
          "1C0                           \r",//100  avec terminateur zero
          "1E0                           \r",//100  avec terminateur zero
          "200                           \r",//100  avec terminateur zero
          "220                           \r",//100  avec terminateur zero
          "240                           \r",//100  avec terminateur zero
          "260                           \r",//100  avec terminateur zero
          "280                           \r",//100  avec terminateur zero
          "2A0                           \r",//100  avec terminateur zero
          "2AC                           \r",//100  avec terminateur zero
          "2AE                           \r",//100  avec terminateur zero
          "300                           \r",//100  avec terminateur zero
          "320                           \r",//100  avec terminateur zero
          "340                           \r",//100  avec terminateur zero
          "360                           \r",//100  avec terminateur zero
          "380                           \r",//100  avec terminateur zero
          "3A0                           \r",//100  avec terminateur zero
          "3AC                           \r",
          "paulfjujo@free.fr             \0"
#pragma
#define CLS 12
#define BS 8
#define TAB 9
#define CR 13
#define LF 10
#define Bell 7
#define STX 0x02
#define ETX 0x03
#define ON 0    // logique inverse avec led tiree au +5V
#define OFF 1
#define OUT_RS232   Drapeaux.Lcd=0;
#define OUT_LCD     Drapeaux.Lcd=1;
#define MAX_LEN 200
#define DureeCycle 10   // 10 x 200mS soit 2sec @10Mhz
#define Led_Rouge LATAbits.LATA4
#define Word unsigned int
#define Byte unsigned char
#pragma udata
unsigned int i,j,k;
unsigned int EAx;
float f1;
unsigned char tampon[16];
unsigned char CRam[32];
//unsigned char Drapeaux ;     // 8 flags
struct chbits {
                 unsigned Stable:1;
                 unsigned standby:1;
                 unsigned elligible:1;
                 unsigned Accumule:1;
                 unsigned Blc:1;
                 unsigned Over:1;
                 unsigned Fill:1;
                 unsigned Lcd:1;
               } Drapeaux;
#pragma idata
static unsigned char Entree[16]="123456789012345";
unsigned char *valtxt=&Entree[0];
static unsigned char Texte[64]="PROJET C18 :18F26K2x_LCD2x16.mcp\r";
unsigned char * txt=&Texte[0];
#define MaxCar_LCD 16.
#define LCD
//#define RS232
//--- Subroutines ================
unsigned char EEPROM_Lect(unsigned int AdrL) ; // lecture a l'adresse adrL
void EEPROM_Ecr(unsigned int AdrE,unsigned char car) ; // ecrit  a l'adresse adrE
void Save_Msg_To_EEPROM(unsigned int * adrx, unsigned char * ptr1);
void PrintOut_Eeprom_Msg(unsigned int PtrE);
void Init_ADC(void);
void Init_Hardware(void);
unsigned int Mesure_ADC(int canal);
void Tempo(unsigned long val);
//------  EEPROM du PIC 18Fx6K2x   1024 bytes !---------------
unsigned char EEPROM_Lect(unsigned int Adr) // lecture a l'adresse adr
    EEADR =(unsigned char)(Adr&0x00FF);
    EEADRH =(unsigned char) ((Adr>>8)&0x0003);   //Bits 2-7 are masked off since EEPROM is only 1KB
    EECON1bits.EEPGD=0;     // 0= adressage EEPROM
    EECON1bits.CFGS=0;      // 0= acces data EEPROM
    EECON1bits.RD=1;        // arme Lecture EEprom
    Tempo(1000L);
    return(EEDATA);
void EEPROM_Ecr(unsigned int AdrE,unsigned char car) // ecrit  a l'adresse adrE
{int dr;
    EEADRH = ((AdrE>>8)&0x03);   //Bits 2-7 are masked off since EEPROM is only 1KB
    EEADR =(AdrE &0xFF);
    EEDATA=car;
    EECON1bits.EEPGD=0;
    EECON1bits.WREN=1;            // autorise ecriture EEPROM
    EECON1bits.CFGS =0;
  if(INTCONbits.GIE ==1)
    INTCONbits.GIE =0 ;
    dr=1;
    EECON2=0x55;
    EECON2=0xAA;
    EECON1bits.WR=1;
    while (PIR2bits.EEIF==0);
    PIR2bits.EEIF=0;
    EECON1bits.WREN=0;
    if (dr==1)INTCONbits.GIE =1;
    while (*ptr1) EEPROM_Ecr(adrx++,*ptr1++);
{ int i,j;
 j=0;
  do
  if ( PtrE >1023) break;
  i = (int)EEPROM_Lect(PtrE);
  if ( i==0) break;
#ifdef LCD
  if (Drapeaux.Lcd==1) XLCDPut((Byte)i);
#endif
#ifdef RS232
 if (Drapeaux.Lcd==0) Put_RS((Byte)i);
#endif
if ((Drapeaux.Lcd==1) && (j > MaxCar_LCD)) break; // limit LCD 16car
  PtrE++;j++;
  while (i!=0)  ;
 Tempo(1000L);
// Tempo(250.000);  2,2 sec avec Q=20Mhz
while(val>0){val--;}
{ unsigned int EA;
  //ADCON0bits.ADON=1;
  ADCON0=1 + (canal<<2);   // ADON=1 et choix de canal
  Delay10TCYx( 10 ); // Delay for 100TCY
  ConvertADC(); // Start conversion
  while( BusyADC() );
  EA = ReadADC(); // Read result
  return (EA);
 // itoa( EAx,tampon);
 // Put_RS('E');Put_RS('A');Put_RS(canal+48);Put_RS('=');
 // k=PutStr_RS(tampon);
 // Tempo(5000L);
void Init_Hardware()
     PORTB = 0xFF;
   TRISB = 0x00;        // All Outputs
   ANSELH=0; // no analog
   INTCON2bits.RBPU=0;      // enable Pull-up
    WPUB=0xFF;               // all pin with pull up
  // ATTENTION a l'ordre des canaux ANALOGIQUES !!!
  ANSEL=0;
  ANSELbits.ANS0=1;     //  analog input on Port RA0   voir page 154
  ANSELbits.ANS1=1;     //  analog input on Port RA1
  LATA = 0x00;
  TRISA = 0b00001111 ;   //RA0,RA1=analog input,  RA2,RA3=input, RA4,RA5=output
  PORTA=0;
  PORTC = 0xFF;          // set PORTC to $FF
  TRISC = 0b10111111;    // all input  expect RC6
  TRISCbits.TRISC0 = 1;
  TRISCbits.TRISC1 = 1;
  TRISCbits.TRISC2 = 1;
  TRISCbits.TRISC3 = 1;
  TRISCbits.TRISC4 = 1;
  TRISCbits.TRISC5 = 1;
  TRISCbits.TRISC6 = 0;  // TX - Set as Output UART RS232 and Bootloader
  TRISCbits.TRISC7 = 1;  // RX - Set Receive pin for UART RS232 and Bootloader
  RCONbits.IPEN=1   ; // enable priority levels
  RCONbits.SBOREN=0;  //  BOR disbled
  SLRCON=0; // standard rate for PORTA,B,C,D,E
void Init_ADC()
    //config lecture ADC 10 bits
    ADCON0bits.ADON=1;      // ADC enabled chanel 0
    ADCON1bits.VCFG1=0;   // +Vref = +5V AVdd
    ADCON1bits.VCFG0=0;   // -Vref = Gnd AVss
    ADCON2bits.ADFM=1;     // right justified
    ADCON2bits.ACQT2=1;
    ADCON2bits.ACQT1=1;
    ADCON2bits.ACQT0=0;    // 16 TAD
    ADCON2bits.ADCS2=1;
    ADCON2bits.ADCS1=0;
    ADCON2bits.ADCS0=1;    // Fosc/16
void main(void)
    Init_Hardware();
    Led_Rouge=ON;
    Init_ADC();
    Delay10KTCYx(250);
    Led_Rouge=OFF;
    OUT_LCD
    XLCDInit();
    Erase_Ligne(1);
    XLCDPut('H'); //write to LCD
    XLCDPut('E');
    XLCDPut('L');
    XLCDPut('L');
    XLCDPut('L');
    XLCDPut('O');
    Delay10KTCYx(250);
    Erase_Ligne(2);
    XLCDPutRomString("COG16 vers.a C18");
    Delay10KTCYx(250);
    Erase_Ligne(1);
    PrintOut_Eeprom_Msg(0x3E0); // fond d'Eeprom  paulfjujo ..
    Delay10KTCYx(250);
    Delay10KTCYx(250);
    txt=&Texte[0];
    //strcpypgm2ram(txt,"PIC18F26K20 3,3V"); // .. OK
    strcpypgm2ram(txt,RS_Str[6]);  //  avec texte en table rom ...ok
    Erase_Ligne(1);
    XLCDPutRamString(txt);
     Delay10KTCYx(250);
    Delay10KTCYx(250);
    Erase_Ligne(1);
    XLCDPutRomString("Mesure CH1"); //partie fixe
    Erase_Ligne(2);
    XLCDPutRomString("Mesure CH2"); //partie fixe
while(1)
  Led_Rouge=!Led_Rouge;
  EAx=Mesure_ADC(0);
  txt=&Texte[0];
  k=sprintf(txt,"%04d",EAx);
  XLCD_pos(1,11);
  EAx=Mesure_ADC(1);
  txt=&Texte[0];
  XLCD_pos(2,11);
  Delay10KTCYx(250);
  • LCD2x16_lite.h.txt
I use 5V power supply for both PIC18F2620 and POWERTIP LCD
Could somebody help me with an example of ISR for an USART application?
Hi jayanth.devarayanadurga,
You asked me last week to send you my code in order to help me. Did you do something?
hello,
example for a 18F26K22 ... to adapt to 18F2620
//26-09-2013  Q=20Mhz au lieu de 10Mhe et 38400 bauds
//03/07/2012
// Pickit3
// TESTE OK  en lecture
// attention: use radix decimal !!
// C18 MPLAB
// directory : _C18\MesProjets_C18\_18F46K22
// Projet :_C18\MesProjets_C18\_18F46K22\18F46K22_test_RS232.mcp
// Source : 18F26K22_test_RS232.c
// linker: 18f26k22_GrosseBank.lkr
========== HARDWARE ====================
27 pf  Q=10Mhz 27pF
Interface DS275 pour liaison UART TTL <-> RS232
PIC 18F26K22  28 pins DIP
PortB
 RB0   21   input
 RB1   22
 RB2   23
 RB3   24
 RB4   25
 RB5   26
 RB6   27  ICSP_Clck   Bleu fonce    Pin5 Pickit2
 RB7   28  ICSP_Data   Bleu clair    Pin4 Pickit2
PORTA
 RA0   2  Analog Input for AC line meaurement
 RA1   3
 RA2   4
 RA3   5
 RA4   6  Output .. Led .. 390 ohms +5V
 RA5   7  Output
 RA6   8  ----- Quartz 10Mhz   C=22pF -- Gnd
 RA7   9  ------ Quartz ---    C=22pF -- Gnd
PORTC
 RC0   11
 RC1   12
 RC2   13
 RC3   14
 RC4   15  SCL I2C  LCD4x20
 RC5   16  SDA I2C  LCD4x20                                      depend si DTE ou DCE
 RC6   17  TX  UART1 --Blc---  3 de DS275 7 -- blanc ----> 2HE10 -nappe --DB9M DB9F cable RS232 PC
 RC7   18  RX  UART1 --rouge-  1 de DS275 5 ---bleu Fce -< 3HE10 -nappe --DB9M DB9F cable RS232 PC
           Gnd ------------------------------------------>5 HE10 -nappe ---DB9M DB9F cable RS232 PC
      1   --- jaune -- VPP/MCLR ---  pin1 Pickit2
      8  ---- blanc ------Gnd-----  pin3 Pickit2
 VSS  8   ----  GND Power
 VSS  19  ----  GND Power
 VDD  20  ----  +5V Power
#include "p18f26k22.h"
#define p18f26k22
#define Versus "Versus 130926 C18   "
#include "stdio.h"
#include <stdlib.h>
#include <delays.h>
#include <string.h>
#include <usart.h>   // pour fonctions UART HARDWARE
#include <adc.h>
#include <ctype.h>
#include <portb.h>
#include <timers.h>
#include <math.h>
// configuration bits set in code !
// voir Help
//  Topics
//        Pic18
//            config bits settings
//                    choisir PIC18F26K22
#pragma config FOSC = INTIO67, FCMEN = OFF, PLLCFG=OFF            // CONFIG1H
#else
#pragma config FOSC = HSHP, PLLCFG=OFF, PRICLKEN=ON ,FCMEN=OFF      // quartz 10Mhz
#endif
#pragma config IESO=OFF,PWRTEN=OFF,BOREN=OFF,WDTEN=OFF,CCP2MX=PORTC1
#pragma config PBADEN=OFF,T3CMX=PORTC0,P2BMX=PORTC0,CCP3MX=PORTB5
#pragma config MCLRE=EXTMCLR,STVREN=OFF,LVP=ON,XINST=OFF,DEBUG=OFF
// Using Q=20Mhz  Clock
#define CLOCK_FREQ 20000000L
#define FOSC 10000000
// config vue sur Pickit3 : 2200 3C18 9900 0084 C00F E00F 400F
#ifndef Byte
#endif
#define MAX_LEN 200
volatile unsigned char buffer[MAX_LEN];	// buffer de reception
#define DureeCycle 10 // * 1 diziemes de secondes => 1,0sec
// Attention use Radix decimal in MPASM options
#define CLS 12
#define BS 8
#define TAB 9
#define CR 13
#define LF 10
#define Bell 7
#define OFF 1
#define Led_Rouge    PORTAbits.RA4
#define Allume 0
#define Eteint 1
//#define ToTest
#ifdef ToTest
// === variables for Testing purpose ====
#endif
unsigned int  i,j,k;
unsigned int dummy;
unsigned int j1;
unsigned int M;
unsigned int BRG_REG;
unsigned char c;
long L;
char Texte[]="18F26K22 test RS232 C18\r\n 26/09/2012 rev a\r\n38400bds Quartz 20Mhz \r\n\0";
char *txt;
volatile unsigned int i1,DataReady1;
volatile char  c1;
volatile unsigned int CptErr;
volatile int count;
//--------- RS232 UART HARDWARE --------------
void Init_UART1(void);
int PutStr_RS(char *s);
void Put_RS(char * untel);
void CRLF();
void Tempo(long val);
void Octet2Hex(unsigned char number);
void Decompile_byte(Byte un);
void InterruptHandlerHigh (void);
void Decompile_byte(Byte un) {
Byte masque;
  masque = 0x80;
  while (masque > 0u )
  if (un & masque)
      Put_RS(49u);  //  '1'
    else
      Put_RS(48u);  //  '0'
    masque =masque >>1;
char high,low;
  // high nibble
  high = ((number & 0xF0) >> 4) + 48; // + '0'
  if (high > '9')
    high =high + 7;
 // low nibble
  low = (number & 0x0F) + 48;          // +'0' low nibble
  if (low > '9')                       // '9'= 57u
    low += 7;                         // > '9'
  Put_RS(high);
  Put_RS(low);
  Put_RS('h');
//gestionnaire d'interruption
// High priority interrupt vector
#pragma code InterruptVectorHigh = 0x08
void InterruptVectorHigh (void)
  _asm
    goto InterruptHandlerHigh //jump to interrupt routine
  _endasm
// High priority interrupt routine
#pragma code
#pragma interrupt InterruptHandlerHigh
void InterruptHandlerHigh ()
 // static unsigned int i1 ; // doit être statique pour conserver sa valeur entre les IT
//======== SERIAL======================
 if(PIR1bits.RC1IF==1) // si une interruption arrive
   if(RCSTA1bits.FERR==1 )
     RCSTA1bits.SPEN = 0 ;
     CptErr++;
     RCSTA1bits.SPEN= 1 ;
     if (RCSTA1bits.OERR==1)    // voir parag 16.1.26 p273
       RCSTA1bits.CREN = 0 ;
       RCSTA1bits.CREN = 1 ;
       CptErr++;
    c1 =Read1USART(); // le lire => RAZ  RCIF
    // for echoed car
    //while(Busy1USART()); // par sécurité
    //if (PORTBbits.RB1==0) Write1USART(c1); // echo
     if( c1 == BS)
         if(i1>0) i1--;
      else
      if((c1 != CR) && (i1<MAX_LEN))
        buffer[i1]=c1 ; // stockage
        i1++;
        }else
         buffer[i1]='\0'; // fin de chaîne si CR
         i1=0;
         DataReady1 =1;
} // fin de routine interrupts
// USART_BRGH_HIGH,32
// init 38400Bd a 20Mhz
// init 19200Bd a 10Mhz avec IT en rx
// voir para 18.5 spec sheet DS41159B page 186
Open1USART( USART_TX_INT_OFF &
USART_RX_INT_ON &
USART_ASYNCH_MODE &
USART_EIGHT_BIT &
USART_CONT_RX &
USART_BRGH_HIGH,32
INTCONbits.PEIE = 0 ; // autorisation des IT des périphériques
INTCONbits.GIE = 0 ; // autorisation globale des IT
	int n;
	for (n = 0; *s; n++, s++)
       	Put_RS(*s);
	return n;
   	Write1USART(untel);
void CRLF()
  Put_RS(CR);  Put_RS(LF);
void main()
 #ifndef ToTest
	OSCCON=0;
	OSCCONbits.SCS=0x10;     // see DS page 37
	OSCCONbits.IRCF	= 7;    // choix 16Mhz
	OSCCONbits.IRCF	= 6;    // choix 8Mhz
	OSCCONbits.IRCF	= 5;    // choix 4Mhz
	OSCCONbits.IRCF	= 4;    // choix 2Mhz
    OSCCONbits.IRCF	= 3;    // choix 1Mhz par defaut !!!
	OSCCON2=0;
	OSCTUNEbits.PLLEN = 1;  // 1=active PLL => 10x4=40Mhz
	OSCTUNEbits.TUN=0x000000;
	#endif
//OSCCON =0b01100000;
ANSELA=0;
TRISAbits.TRISA4 = 0;   // led rouge
LATA = 0x00;
ANSELC=0;
Led_Rouge=Allume;
Init_UART1();
Put_RS('*');
CRLF();
Put_RS('#');
CRLF();
Put_RS(CLS);   // clear  Vbray terminal Screen
Tempo(1000000L);
txt=&Texte[0];
k=PutStr_RS(txt);
CRLF();
Tempo(20000);
// write to the USART
//k=fprintf(_H_USART,"Init UART 19200bds Q=10Mhz\r\n");
k=fprintf(_H_USART,"Init UART 38400bds Q=20Mhz\r\n");
k=fprintf(_H_USART,"hello\r\n");
k=fprintf(_H_USART,"Type some chars and CR to send them: ");
buffer[0]=0;
DataReady1=0;
i1=0;
c1=0;
CptErr=0;
// init pour interruptions ----
  INTCONbits.GIE = 1;    // active global interrupt
  INTCONbits.GIEL=1;
  RCSTA1bits.CREN= 1 ;
  PIE1bits.RC1IE = 1;
  INTCONbits.PEIE = 1;   // autorisation des IT des périphériques
#endif
//=========Zone for short tests===================
 while(1)
 if (DataReady1==1) // test if reception occured
  j=0;
  Led_Rouge=Allume;
 k= fprintf(_H_USART,"\r\nKeyboard entry : ");
  while (buffer[j]!=0)
    c=buffer[j];
    Put_RS(c);
    j++;
  DataReady1=0;
  buffer[0]=0;
  i1=0;
  Led_Rouge=Eteint;
if (CptErr>0)
    k=fprintf(_H_USART,"\nNombre erreur %5d\n",CptErr);
    CptErr=0;
//Led_Rouge=!Led_Rouge;
/* results on Vbray terminal
 03/07/2012 rev a
hello
Keyboard entry : 12345678901234567890123456789012345678901234567890123456789A123456789012345678901234567890B
17:50:14.656> Keyboard entry : 12345678901234567890123456789012345678901234567890123456789A123456789012345678901234567890B
17:50:14.906> Keyboard entry : 12345678901234567890123456789012345678901234567890123456789A123456789012345678901234567890B
17:50:15.093> Keyboard entry : 12345678901234567890123456789012345678901234567890123456789A123456789012345678901234567890B
17:50:16.906> Keyboard entry : 12345678901234567890123456789012345678901234567890123456789A123456789012345678901234567890B
17:50:17.156> Keyboard entry : 12345678901234567890123456789012345678901234567890123456789A123456789012345678901234567890B
17:50:17.406> Keyboard entry : 12345678901234567890123456789012345678901234567890123456789A123456789012345678901234567890B
program ScriptTest;
const STRING1 =
'12345678901234567890123456789012345678901234567890123456789A123456789012456789Z';
var i,j: longint;
begin
j:=0;
  for i:=0 to 8 do
  begin
  comsendstr(STRING1);comsendchr(13);
Delay(20);
  end;
  end;
end.
hello,
Here is my project file attached.
I made a test app, where I read char-by-char from Hyperterminal, and then I display on the LCD. In my opinion, it works as expected.
lcd_goto() routine works.
Please find below the code:
some remarks:
char rxarray[23]="";
char string[23]="";
if you want to display on LCD2x16 , it's better to init with 32
char rxarray[32]=0;
char string[32]=0;
unsigned char rxchar="",r=0,flag=0, icount=0,check=0,col,row;
i'm not sure it's a good way to put ""
better is
unsigned char rxchar=0;
it's difficult to read your code with a lot of dead code....
i add a test to avoid overlap of table size
i didn't test it , but it seem able to work
while(1)
		if(PIR1bits.RCIF==1)
			rxchar=ReadUSART();
			TXREG=rxchar;
			PIR1bits.RCIF=0;
 [B][COLOR="#0000CD"] // test if overlap the array[/COLOR][/B]
			if((rxchar!='\r') && (r<31))
				rxarray[r]=rxchar;
				string[r]=rxarray[r];
				r++;
				col++;
				flag=0;
			if(rxchar=='\r')
				m=r-1;
				r=0;
				col=0;
				row=1;
				flag=1;
				for(i=0; i<strlen(rxarray); i++) rxarray[i]='\0';
				TXREG=12;
				cmd(0x01);
				for(i=0; i<=m; i++)
					col=i;
					if(col<16 && row==1)
				 		lcd_goto(0+col);
					if(col>=16 && row==1)
						col=0;
						row=2;
						lcd_goto(20+col);
					send_char(string[i]);
					Delay10KTCYx(3);
					col++;
				} // for
			   }// if(rxchar=='\r')
		} //if PIR
	}// while(1)
Hello!
I have had a look at your code.
Apparently, since you use <string.h>, you can probably also use <stdio.h>, right?
In this case, why not using existing libraries.
Example: you write a send_dec_lcd function that does nothing more than printf, and on top of that,
it does not perform it nicely. Here is an alternative (not tested, I don't use PIC).
Code C - [expand]
8
9
10
11
#include <stdio.h>
#include <string.h>
#define LINE_LEN 17      // 16 + ending 0. Adapt the size to your LCD
char lcd_line[LINE_LEN] ;
void send_dec_lcd(unsigned long data) {
    sprintf(lcd_line, "%ld", data);
    lcd_string(lcd_line);
Now about lcd_string function: It might not be safe. If something happens to your string
so that the ending 0 goes to hell, then your function will never end. I would recommend:
Code C - [expand]
void lcd_string(const char *s) {
    uint8 i;
    while((s[i] != 0) && (i < LINE_LEN)) {
        send_char(s[i]);
        i++;
NB: I could use send_char(s[i++]) but I don't like cryptic code, and I verified that my compiler
does exactly the same code, so it's not slower, neither faster.
Beside this:
- You should avoid goto instructions. It's not BASIC, neither FORTRAN, but C, and there is
always a way to do without goto.
- Your main program is too long. Be it a main program or a simple function, a good way to
do understandable code is to write every function in max 1 page of your editor, so that you
can see everything at once.
- Your switch(database): the code in all the cases is about the same. I'm sure you could
write a small function instead of it.
- You should use the preprocessor. Example: while(i < 26). Why 26? You should define it with
some self-explanatory macro. Similarily, while (mode == 0). For example in my current program,
I use an SD card. The initialization status can be SD_PROTECTED, SD_MISSING, SD_OK.
If anybody reads this code
Code C - [expand]
8
9
10
sd_status = SDInit();
if(sd_status == 0) {
   // Do something
else if(sd_status == 1)  {
   // Do something else
else {
  // Do another thing.
then he will have to understand what is status = 0, 1, 2
Now if you write:
Code C - [expand]
8
9
10
if(sd_status == SD_OK) {
   // Do something
else if(sd_status == SD_PROTECTED)  {
else { // sd_status == SD_MISSING
then you don't even have to read the documentation (if any) or read the SDInit function
itself to understand what is returned.
And as somebody else told you, you shouldn't put all the code in a single file.
What if you have to write another program with the same LCD? You will copy-paste the relevant functions?
If you write a lcd.c / lcd.h, then you can reuse the files as they are.
Just a smarter way to organize your code: <> means directory
<Development root>
- <common>
- <devices>// With a few examples here, EEPROM, LCD, SD card
--EP24C.h
--EP24C.c
--LCD.h
--LCD.c
--SD.h
--SD.c
<CPU>
-<pic 16> // One type of pic and its related utilities
--pic_16_utils.h
--pic_16_utils.c
-<pic 24> // Anoher PIC type
- <projects>
-- <project1>
-- <project2>
etc...
If you write LCD.h and .c when writing project 1, then you just have to include it in project 2 (and set the <devices> path
to your linker). That's all.
Dora.
Hello!
Code C - [expand]
8
9
10
11
#include <stdio.h>
#include <string.h>
Dora.
Hi doraemon,
Using inbuilt functions is the best practice but a small suggestion using sprintf could crash the program by exceeding the printed string in the passed string size, so the better practice is using snprintf, that will limit the printed string in allocated space.. I have faced the problem of changing the values of adjacent variables unpredictable after that only i corrected the sprintf....
Regards,
Venkadesh M
I implemented an ISR for USART RX, but I still have problems when "time is up" messaged is sent approximately in the same time with the "ok" one, because only parts of the message is displayed. Below is attached the code.
Could you help me plese?
#include <p18f2620.h>
#include <delays.h>
#include <string.h>
#include <usart.h>
// Pragma
#pragma config WDT = OFF			// watch dog disabled
#pragma config OSC = INTIO67
#pragma config IESO = OFF			//Oscillator Switchover mode disabled
#pragma config XINST = OFF
#pragma config BOREN = OFF  		//Brown-out Reset disabled in hardware and software
#pragma config PBADEN=OFF			//PORTB<4:0> pins are configured as digital I/O on Reset
#pragma config STVREN=OFF			//Stack full/underflow will not cause Reset
#pragma config LVP=OFF				//Single-Supply ICSP disabled
#pragma config MCLRE=ON				//MCLR pin enabled
//                            CONSTANT DEFINITION
# define databits LATC				// LCD 4 bit data PORT
# define data0 PORTBbits.RB4		// data0(green wire) of RFID tag
# define data1 PORTBbits.RB3		// data1(white wire) of RFID tag
# define btn1 PORTCbits.RC4			// button for save mode (active low)
// Variables
	char txarray[9]="";
	char string[23]="";
	int i=0,q,m=0;
/** L O C A L   F U N C T I O N S  *******************************************/
void set_hi_nibble(unsigned char data)		// output hi nibble data on port lines
	unsigned char temp=LATC;
	temp= temp & 0xF0;
	temp= temp | (data>>4);
	LATC=temp;
void set_lo_nibble(unsigned char data)		// output low nibble data on port lines
	temp= temp & 0xF0;
	temp= temp | (data & 0x0F);
	LATC=temp;
void en_set(void)			//function used to set Enable signal properly
	LATAbits.LATA6 = 1;		// Set EN on 1
	Delay1KTCYx(1);
	LATAbits.LATA6 = 0;		// Set EN on 0
void send_char(unsigned char c)
	LATAbits.LATA7=1;		// set RS on 1
	set_hi_nibble(c);
	en_set();
	Delay1KTCYx(5);			// delay 50ms
	set_lo_nibble(c);
	en_set();
	Delay1KTCYx(5);			// delay 5ms
void cmd(unsigned char c)
	LATAbits.LATA7=0;		// set RS on 0
	set_hi_nibble(c);
	en_set();
	set_lo_nibble(c);
	en_set();
void InitUART(void)
	TXSTAbits.TX9=0;
	TXSTAbits.TXEN=1;
	TXSTAbits.SYNC=0;
	TXSTAbits.BRGH=1;
	TXSTAbits.TX9D=0;
	RCSTAbits.SPEN=1;
	BAUDCONbits.BRG16=0;
	SPBRG=25;				// 9600KBaud
	// receive config
	RCSTAbits.RX9=0;
	RCSTAbits.CREN=1;
	RCSTAbits.RX9D=0;
void LCDInit(void)
 	Delay10KTCYx(20);		//Delay 200ms
	LATA=0;
	LATC=0;
	//Outputs
	//Inputs
	ADCON1=0b00001111;
	// Interrupt config
	INTCONbits.GIE=1;
	INTCONbits.GIEH=1;       	// enables all high priority interrupts
	INTCONbits.PEIE=1;
	Delay1KTCYx(15);		//Delay 15ms
	LATC=0x3;
	en_set();
	LATC=0x3;
	en_set();
	Delay100TCYx(1);		// delay 100us
	LATC=0x3;
	en_set();
	Delay10TCYx(4);			// delay 40us
	LATC=0x2;
	en_set();
	//Function set
	//Clear Display
	Delay1KTCYx(2);		// delay 2ms
	Delay100TCYx(10);	// delay 1ms
void putch(unsigned char byte)
	while(!TXSTAbits.TRMT);
	TXREG=byte;
void send_dec_usart(void)		//convert binary number and display number in decimal
	txarray[8]='\r';
	q=0;
	while(q<=8)
		putch(txarray[q]);
		q++;
void lcd_goto(unsigned char data)						//set the location of the lcd cursor
 	if(data<16)											//if the given value is (0-15) the
	{													//cursor will be at the upper line
	 	cmd(0x80+data);
	else												//if the given value is (20-35) the
	{													//cursor will be at the lower line
	 	data=data-20;									//location of the lcd cursor(2X16):
		cmd(0xC0+data);									// -----------------------------------------------------
	}													// | |00|01|02|03|04|05|06|07|08|09|10|11|12|13|14|15| |
}														// | |20|21|22|23|24|25|26|27|28|29|30|31|32|33|34|35| |
	while(*s)
		//	Delay1KTCYx(10);	//Delay 10ms
			send_char(*s++);
void writeString(const char *s)
	while(*s)
		TXREG=*s;
		s++;
  _asm
  _endasm
#pragma code
void InterruptHandlerHigh()
	if(PIR1bits.RCIF)
		if(RCSTAbits.FERR==1)		// frame eror
		//	rxchar=ReadUSART();
			RCSTAbits.CREN=0;
			RCSTAbits.CREN=1;
		if(RCSTAbits.OERR==1)		// overrun error
			RCSTAbits.CREN=0;
			RCSTAbits.CREN=1;
		rxchar=ReadUSART();
	//	TXREG=rxchar;
		PIR1bits.RCIF=0;
		if(rxchar!='\r')
			rxarray[r]=rxchar;
			r++;
			col++;
			flag=0;
		if(rxchar=='\r')
			m=r-1;
			r=0;
			col=0;
			row=1;
			flag=1;
		//	TXREG=12;
			cmd(0x01);
///////////////////functia main///////////////////////////////////////////
void main()
	//Initializations
	PORTC=0x00;
	LCDInit();
	InitUART();
	r=0;
	col=0;
	row=1;
	flag=0;
//	TXREG=12;
	while(1)
		if(flag==1)
			for(i=0; i<=m; i++)
				col=i;
				 	lcd_goto(0+col);
					col=0;
					row=2;
					lcd_goto(20+col);
				Delay10KTCYx(3);
			flag=0;
	}// while(1)
}//main
I don't use Proteus, just MPLAB, C18 compiler
hello,
How do you send the messages ?
is there a <CR> at the en of each message ?
or value 0 ath then end ?
sometime terminal send <LF><CR> when typing Enter
and LF can erase a part of message...
try to supress the Delay here
Delay10KTCYx(3);
because LCD writing take a long time, and you RAZ flag after writing on LCD
Put a led ON inside treatment of ERROR COM to detect if FrameERR or OVERerr occurs.
LATCbits.LATC4=0;  // led FERR off
LATCbits.LATC5=0; // led OERR oof
while(1)
			RCSTAbits.CREN=0;
			RCSTAbits.CREN=1;
                        LATCbits.LATC4=1;
			RCSTAbits.CREN=0;
			RCSTAbits.CREN=1;
                     LATCbits.LATC5=1;
Actually, to send those 2 messages, I use the below functions:
char string1[5]="ok";
char string2[15]="time is up";
void display_ok(void)
	for(k=0; k<strlen(string1); k++)
		{ WriteUSART(string1[k]);
	TXREG='\r';
void display_nok_time(void)
	for(k=0; k<strlen(string2); k++)
		{ WriteUSART(string2[k]);
	TXREG='\r';
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
unsigned char *msg[2]= {"ok", "time is up"};
void UART_Write(unsigned char uartData){
    TXREG = uartData;
void UART_Write_Text(unsigned char msgIdx)
    while(*msg[msgIdx])
         UART_Write(*msg++);
    UART_Write(0x0D);
    UART_Write(0x0A);
UART_Write_Text(0); //Prints "ok"
UART_Write_Text(1); //Prints "time is up"
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
void InterruptHandlerHigh(void);
void
  _asm
  _endasm
#pragma code
void InterruptHandlerHigh(){
Your function to send msg are OK
but try to add a little delay between invoice of each car
ie: Delay10TCYx(1);
because the treatment of receive interrupt flag takes too long time in the main...
Delay10KTCYx(3);    <- cancel this
