Problem with CST low speed when doing a project
ziobleed
Newbie level 6
Newbie level 6
i all
when i implement an example in CST, it calculatesvery fast and end simulation successfully
when i design my own project it takes a lot of more time and somethimes fails
ie : abnormally termination
i checked all the settings , and, i think, are the same of the examples(similar to my project ),what i do wrong ?
bye!!
zb
Re: CST very slow
It usually happen when the mesh is not correct or port is not defined properly. its better if u upload ur project.
Re: CST very slow
this is a project im working on
its very slow on calculation
the ports are well set ?
and lumpedelements?
itwas optimized in microwave office, then exported in CST by a DXF layout file
at this point another questionis : what are the settings in CST that simulate at best the settings in MWO ?
tnx for youranswer
zb
Re: CST very slow
hi,
did you solve this problem or do you still need help with it?
aw
Added after 8 minutes:
hi again,
there are two things here
the ratio limit is quite high - time step is small since unecessary mesh points are used due to the cad import - try ratio limit 10
you've also set lines/wavelength = 8 - this should never be done - the wavelength sampling lower limit should always be at least 10
it seems to be fast enough (for the first mesh adaption pass.....)
good luck!
aw
Added after 1 minutes:
hi again,
good luck!
aw
    ziobleed
Re: CST very slow
tnx for answer
so it can be said that the big number of meshes depended by the cad import from microwave office to CST
if i design it directly to Cst it will be more fast ?
where can i check value of timestep ?
bye, however tnx
zb
Re: CST very slow
The mesh also depend upon the span of frequency u want to run the simulation.
