Re: icd2 help needed
Hai
Sometimes in the past this happened to me also.
First disconnect ICD.In MPLAB folder go to utilities,run MPUsbclean.
Then .For sure once again reinstall MPLAB (for sure),And connect ICD ,then USB device will be detected.Show the driver in the ICD2usb folder in programe files MPLAB.(Do not allow OS to pic default driver!- datasheet says!!) Check for Microchip firmware loader loaded in device manager. If ICD wiring proper should work!
Good luck
Picstudent
