Em_13
Junior Member level 3
Hi,I have built a simple toggle switch with 4013 common dual flip-flop ic.The toggle buttons work fine,so Everything is ok except primary state of output.The output (PIN 1 & 13)state is high when I connect Vcc to circuit despite the inputs are on low state .What should I do to keep output in low state when connect VCC to circuit ?
