problem with cadence ic 5033 and mentor calibre
mydreamhouse
calibre viewer is not running
i have install Cadence ic 5033 and calibre 2006 on redhat 9
layout and simulation are ok, but there is error when run drc ,lvs pex with calibre 2006
the error message is connect error. but the socket has been created successfully on sockt 8192 when run calibre interactive. why the calibre can't communication with cadence layout view???
error messages:error:Could not connect to socket 9189 on host localhost. Probable causes: 1. The layout viewer is not running, or 2. The layout viewer's server sockt is not activated.
tsinghua
Full Member level 4
9189 localhost cadence
You should add calibre menu to virtuoso layout window and invoke calibre from this menu.
Calibre has included skill script to load this menu.
mydreamhouse
could not connect to socket 9189
i had add the script ,and it can load in cadence layout viewer, but it can't communication with layout viewer.why?
thanks!!!
