Hi friends
Iam struggling with 16 bit pwm using Silabs C8051F005.with this iam not getting PWM frequency more than 250 Hz. I want PWM with 1Khz or more.
I used PCA for PWM and Timer0 for PCA time base.
This is my C code. Can anybody suggest for this.
Thanks in Advance
Amarnadh
#include <c8051f000.h>
#include <stdio.h>
#include <string.h>
//#include <math.h>
sbit PWM_OUT= P0^0;
sbit test = P0^1;
//sbit T2 = P0^5; // counter inputT2
//sbit PWM_CCW= P0^5;
sbit PWM_CCW= P0^6;
sbit PWM_CW = P0^7;
#define PWM_START 0x8000
unsigned PWM = PWM_START;
unsigned int DIR;
void SYSCLK_Init (void)
int n;
OSCXCN = 0x67; // EXTERNAL Oscillator Control Register
for (n=1;n<255; n++) ; // XTLVLD blanking interval (>1ms)
while ((OSCXCN & 0x80)== 0 ); // wait for xtal osc to start up
OSCICN = 0x88; // Internal Oscillator Control Register
// select external oscillator as SYSCLK source and
// enable missing clock detector
void Rx_byte()
while(!RI); //wait until RI flag set
RI=0; // clear RI flag
void Tx_byte(unsigned char c)
SBUF=c;
while(!TI); // wait until TI flag set
TI=0; // clear TI flag
void delay_ms(unsigned int i)
int j;
for (j=0;j<i;j++)
TMR3CN=0x04;
// timer3 reload value=64614 for 1ms.
TMR3RLH = 0xFC; // Timer 3 Reload Register High Byte
TMR3RLL = 0x66; // Timer 3 Reload Register Low Byte
while (TMR3CN==0x04);
TMR3CN=0x00;
void Tx_string(unsigned char a[])
unsigned char i;
delay_ms(100); //delay required
for(i=0;a!='\0';i++)
Tx_byte(a);
void PORT_Init (void)
XBR0 = 0x08; // XBAR0: Initial Reset Value
XBR1 = 0x00; // XBAR1: Initial Reset Value,Timer2 External I/P Enable
XBR2 = 0x40; // XBAR2: Initial Reset Value
// Port configuration (1 = Push Pull Output)
PRT0CF = 0x01; // Output configuration for P0
PRT1CF = 0x00; //
PRT2CF = 0x00; // Output configuration for P2
PRT3CF = 0x00; // Output configuration for P3
void UART0_Init (void)
SCON = 0x50; // Serial Port Control Register; mode1,8bit UART,enable rcvr
SCON &= 0xFC; //clear interrupt pending flags
PCON = 0x80; // Power Control Register SMOD=1,doubles clock to UART
void timer(void)
// Timer Configuration
CKCON = 0x08; // Clock Control Register timer 0 uses sys clk
TH0 = 0x00; // Timer 0 High Byte
TL0 = 0xFF; // Timer 0 Low Byte
TH1 = 0xB8; // Timer 1 High Byte,Baudrate value for 9600
TL1 = 0x00; // Timer 1 Low Byte
TMOD = 0x02; // Timer0 mode is 16bit counter,Timer1 Mode is 8bit counter/timerwith autoreload
TCON = 0x30; // Timer Control Register Timer 1 enabled,timer0 overflow flag set
void PCA_Init (void)
// PCA Configuration
PCA0MD = 0x05; // PCA time base=Timer0 overflow PCA Mode Register and disable the CF interrupt
//PCA0CN = 0x40; // Enable PCA counter
PCA0H = 0x00; // PCA Counter/Timer High Byte
PCA0L = 0x00; // PCA Counter/Timer Low Byte
//Module 0
PCA0CPL0 = (0xff & PWM);
PCA0CPH0 = (0xff & (PWM >>8) ); // Right shift 8
PCA0CPM0 = 0x4D;//0x49; // PCA Capture/Compare Register 0 Enable comparator function
// High speed o/p mode
void timer0_ISR (void) interrupt 1
//test = ~ test;
TR0=0; // Timer0 Disable
TH0 = 0xFF; // Timer 0 High Byte PWM frequency this value is for 200hz
TL0 = 0xFF; // Timer 0 Low Byte PWM frequency
TR0=1; // Timer0 Enable
void PCA_ISR (void) interrupt 9
///test = ~ test;
if (CCF0)
CCF0 = 0;
if(PWM_OUT)
PCA0CPH0 = (0xff & (PWM >>8) ); //Right shift 8
else
PCA0CPL0 = 0;
PCA0CPH0 = 0;
} else if(CCF1)
CCF1 = 0;
} else if(CCF2)
CCF2 = 0;
} else if(CCF3)
CCF3 = 0;
} else if(CCF4)
CCF4 = 0;
} else if(CF)
CF = 0;
void main(void)
WDTCN = 0xDE; // Disable WDT
WDTCN = 0xAD; // Disable WDT
PORT_Init ();
SYSCLK_Init ();
timer ();
PCA_Init ();
UART0_Init();
IE = 0x82; // Enable T0 and Global interrupts
//IP = 0x02; // Set Timer0 Interrupt Priority to high
//EA = 1;
EIE1 |= 0x08; // Enable PCA Interrupt
EIP1 |= 0x08;
PCA0CN = 0x40;
while(1)
PCON |= 0x01;
