Problem with autorouting Eagle schematic file
zahidkhan
Member level 2
Member level 2
eagle autorouter setup
hi
i have a Eagle Schematic file. when i make board file with autorouting it makes a final file double sided. how can board file me confined to single sided pcb design.
regards...
Re: Eagle Autorouting
in the Autorouter setup set the top layer (1) to: N/A
Thanks M!C ii did it already but it does not route the vias of that layer which select as N\A.. May i send u the .sch file ?
hi,
- see example, subject: singleside and look at layer cost, top or bot restrict.
:D
