amirahmadian
Member level 1
Problem with ARM microcontroller ethernet controller and DP83848 chip
I've written a simple program for LPC1768 microcontroller (ARM Cortex-M3) in order to interface ethernet network, I just need to receive network packets at the first step. I've used DP83848C chip as the PHY (via RMII interface). For the 10Mb/s ethernet everything works well and I'm able to receive packets (frames) corrrectly (I have tested it with JTAG Debug). But the problem is for 100Mb/s mode. When the network works at 100M speed, the packets are received incomplete (truncated) and some bytes in the end of the packets are not received. Even sometimes the entire packet is missed! Since my program works very well in 10Mb mode, I doubt if there is a problem in software or hardware.
Other information:
1. I set the PHY at Auto Negotiation mode
2. I set the IPGT and SUPP registers correctly according to duplex and speed mode
3. I use IAR compiler
Other information:
