jg001
Newbie level 6
I have a problem with a simple LPF circuit. The circuit, input voltage and output voltages are shown in the attached PDF file. My designed LPF has a cutoff frequency of 10kHz. I input a 5kHz signal in it and measured it with a pair of wires (between ground and the output) which are connected to an oscilloscope. My problem is that when I measure the output with these two wires, the LPF output seems to have a very high frequency signal (15.8MHz) that is being modulated by the 5kHz output. But, when I connect a 1k-ohm resistor in series with the output and then measure it using the two wires, the output is a nice 5kHz signal. Once again, if you look at the attached plots, you'll see what I'm talking about.
I don’t know why this is happening! Any help? Thanks.
