Pankajghawte
Newbie level 6
I'm using attached circuit to switch 5V relay.
instead of using resi.1K and transistor 2N 3904 I'm using resi. 100 ohm and transistor 2N2222. But the issue with the circuit is that when I press button relay gets ON and stays high even after releasing button and gets OFF when I again press the button but if I press and hold button (accidently) more than 1sec (I guess) the relay gets ON initially and gets OFF immediately. Please advise correct action.:|
Regards,
Pankaj
Regards,
Pankaj
