when I type the comand ./install after copying the install.ixl folder to /opt/mentor , it gives me this error:
*** Warning with: ./install
The version of /usr/bin/java may not be correct!
...Required: "1.6.0"
...Found: java version "1.7.0_181"
OpenJDK Runtime Environment (rhel-2.6.14.10.el6-x86_64 u181-b00)
OpenJDK 64-Bit Server VM (build 24.181-b00, mixed mode)
...Please check that you have correctly installed the Mentor Install program that contains the Java Runtime Environment.
Error: Could not find or load main class com.mentor.install.controlpanel.Install
Your help appreciated.
