redtomato11
Newbie level 1
my name ist Tobi and i'm studying Electrical engineering.
I started to learn system verilog and i am trying to program a cyclone 2 on an EP2C5 mini board.
I use Quartus 2 13.0spi1 Web Edition. My problem is weird behaviour in a program that i wrote. It is just supposed to count the number of times
i pressed a button and display the number in binary on 3 LEDs. I have a register as the counter and a module i found on the internet that handles
the button logic. It works, but if i change the mapping between the LEDs and the counter output it doesn't work anymore
I changed counter[2:0] to counter[0:2] and it has the same behaviour just the other way around with counter[2]
P.S. this is my first forum question. Tell me if i did something wrong
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 module getting_pro( input PB, input clk, output LED0, output LED1, output LED2 ); reg[2:0] counter; //reflects state (pushed/not pushed) wire PB_state; //is 1 for one clock cycle if button gets pressed wire PB_up; //is 1 for one clock cycle if button gets released wire PB_down; //debouncer module i found PushButton_Debouncer debouncer( .clk(clk), .PB(~PB), .PB_state(PB_state), .PB_up(PB_up), .PB_down(PB_down) ); //the not is because the LEDs are on when the Pin is 0 //The weired stuff happens here assign LED0 = ~counter[0]; assign LED1 = ~counter[1]; assign LED2 = ~counter[2]; //if i change it to this assign LED0 = ~counter[2]; assign LED1 = ~counter[1]; assign LED2 = ~counter[0]; //the leds blink as if counter[0] wouldn't exist // it counts up normally and resets normally it just starts with setting counter[1] always_ff @(posedge PB_down) begin //if counter smaller than 7 count up , otherwise set counter to 0 if(counter < 3'b111) begin counter <= counter + 3'b001; end else begin counter <= 3'b000; end end endmodule
