Alex Aldridge Arabaolaza
Newbie level 2
Hi mates, i'm trying to perform some measurements using a CS5460A (Cirrus Logic) microcontroller and an ATMega8 from AVR.
Here is my initialization code for the CS5460A:
After that, I try to perform some reads but the program seems to hang (it should light a LED after 20 seconds but it never lights)
This is my code to perform a read:
Do you have any idea of what could be wrong here?
Thanks in advance,
ALex
#define CONFIG_REGISTER 0x40
#define CYCLE_COUNT_REGISTER 0x4A
#define STATUS_REGISTER 0x5E
#define MASK_REGISTER 0x74
void initCS5460A(){
unsigned char temp;
CLEARBIT(PORTD, PD_RESET); //Give CS5460 a h/w reset (PD4 = 0)
SETBIT(PORTB, PB_CLCS); // waste some time (2.9 us?)
SETBIT(PORTD, PD_RESET); //
//The resistor on MS_RESET will add another delay. Need to wait some us after reset pulse before starting CS5461 comms
tm_cs5460 = 0;
er_cs5460 = 0;
/*This function is used whenever CS5460A is reset so each time we need to reset the following values*/
SETBIT(ms_flags, MS_1ST_READ); //Used to discard first read
CLEARBIT(ms_flags, MS_CS_RESET); //Disable reset flag (it has been already done)
CLEARBIT(tb_flags, TB_INT_LOW);
//Output initialisation sequence to CS5461 via SPI
init_CS5460A_send_sequence();
void init_CS5460A_send_sequence(){
CLEARBIT(PORTB, PB_CLCS); //Enables SPI communication
//Resync
cs5460_send(0xFF);
cs5460_send(0xFF);
cs5460_send(0xFF);
cs5460_send(0xFE);
//soft reset
cs5460_Write_data(CONFIG_REGISTER, 0x000080);
//Resync
cs5460_send(0xFF);
cs5460_send(0xFF);
cs5460_send(0xFF);
cs5460_send(0xFE);
//configure (x10 gain for current)
cs5460_Write_data(CONFIG_REGISTER, 0x000061);
//set integration period (72 clocks)
cs5460_Write_data(CYCLE_COUNT_REGISTER, 0x000048);
//reset all bits in status register (IC* bit ignored)
cs5460_Write_data(STATUS_REGISTER, 0xFFFFF);
//set DRDY in mask register (for INT*)
cs5460_Write_data(MASK_REGISTER, 0x800000);
//start continuous computation cycles
cs5460_send(0xE8);
SETBIT(PORTB, PB_CLCS); //Disables SPI communication
void cs5460_sync(){
/*This functions sends the init sequence that the CS5460A needs to start operating*/
unsigned char sync_sequence[] = {0xFF, 0xFF, 0xFF, 0xFE};
unsigned char iterator = 0;
for (iterator = 0; iterator < 4; iterator++){
cs5460_send(sync_sequence[iterator]);
unsigned long int cs5460_Read_data(char cData)
char spi_data1=0,spi_data2=0,spi_data3=0;
/* Start transmission */
cs5460_sync();
SPDR = cData;
/* Wait for transmission complete */
while(!(SPSR & (1<<SPIF)))
spi_data3=SPDR;
SPDR = 0xff;
spi_data3=SPDR;
SPDR = 0xff;
spi_data2=SPDR;
SPDR = 0xff;
spi_data1=SPDR;
return (0x00FFFFFF & (((spi_data3*65536) & 0x00FF0000)|((spi_data2<<8) & 0x0000FF00)|(spi_data1& 0x000000FF)));
Thanks in advance,
ALex
