[AVR] Problem on Data transmission through RS485 over Atmega32
Prayuktibid
Newbie level 6
I am trying to communicate between two Atmega32 through RS485 Driver .. I am using MAX487 IC and Atmega32 MCU, whenever I am simulating on Proteus its not giving any output.. I have done many way but I unable to solve this. Please help me.
Here my schematics
This is my code
HTML:
#include <inttypes.h>
#include <avr/io.h>
#include <util/delay.h>
#include <avr/interrupt.h>
#define MAXTTEpin 2
#define SET_MAXTE(a,b) ( (a) |=  (1 << (b) ) )
#define CLR_MAXTE(a,b) ( (a) &= ~(1 << (b) ) )
#define Led 1
#define Button 1
/*Initilize RS485 data Transmission*/
void RS485init(void)
	DDRD|= (1<<MAXTTEpin); 						//make max transmitter enabled pin OUTPUT
	CLR_MAXTE(PORTD,MAXTTEpin);			 		//Clear Transmitter enabled pin
	UCSRB|=(1<<TXEN)|(1<<RXEN)|(1<<RXCIE);	                        //Enabled transmitter and Receiver and Interrupt on RXC
	UCSRC|=(1<<URSEL)|(1<<UCSZ1)|(1<<UCSZ0);                        //SET 8 Character, one stop bit, No parity
	UBRRL=0x33;						        //Set baud 9600
	sei();								//Set Interrupt
/*IRS485 data Transmitter*/
void RS485Transmitt(char x)
	  SET_MAXTE(PORTD,MAXTTEpin);
      _delay_ms(1); 				        //Set Transmitter enabled pin
	 while(!(UCSRA&(1<<UDRE)));					//Check whether Transmitter data buffer is empty or not
			UDR=x;                                          //Receive data on UDR register
	while(!(UCSRA&(1<<TXC)));					//Check whether Transmission complete or not
			UCSRA|=(1<<TXC);                                //Make TXC HIGH
	_delay_ms(1);                                      //Clear Transmitter enabled pin
/*IRS485 data Receive Inturrept Vector*/
ISR(USART_RXC_vect)
    cli();
	PORTA = UDR;
	_delay_ms(1);
    sei();                                                 //send data to port A from UDR
/*Main Function*/
int main()
    char data=0;
	DDRA|=(1<<Led);
    DDRB&=~(1<<Button);   							//make pin0 OUTPUT and other pins are INPUT of PORTA
	RS485init();                                                    //Initialize Trans receiver
	while(1)
		data=PINB;                                              //Take data from Pin A
		RS485Transmitt(data);
		_delay_ms(1);                                    //Transmit Data
and Oscilloscope Output
according your scope picture it is working like expected.
For further debug:
Show the state of both RE signals.
I wonder why you used RS485 driver.
* for short distance there is no need for RS485, just connect the Tx with the Rx, with CMOS levels.
* for long distance you need a proper 120 Ohms twisted pair cable and the termination resistors.
Klaus
Thanks for reply
For further debug: Show the state of both RE signals.
Both RE signals are same as above.. I have observed in Scope.
as per you its working fine then why I am not getting output? as per circuit diagram and code Leds should glow at the initial(when simulation will start) there after Leds will respond according to Buttons respectively. but nothing is happening.
I am exploring the RS485 cause I am newbie in this field.
I can´t find them in the scope picture.
Both RE signals with the same value?... doesn´t make sense. One should be the driver, the other the receiver.
Indeed I recommend to leave both receivers active all the time and only swith the trasmitters active/inactive (DE signals).
When using RS422/485 ... use the termination resistors.
It seems, that the hardware is working, so I assume there is a problem with your code.
Klaus
See the Scope output
I am newbie in this field please guide me how I will proceed?
I still can´t see if RE1 and RE2 is HIGH or LOW. I just see a straight line.
/RE = low active. Set them active = connect them continously to GND.
Set DE signals according data direction.
Klaus
I'm a little bit confused about schematics. Do I understand right that you try to measure both TXD and RXD at the U3 side?
At the source code I can see driving DE/RE# in the right way. But again, the scope picture above shows a transmitting, and both RE# are the same. I can suggest that DE/RE# are HIGH at this point, so both microcontrollers are trying to drive the line. Thus no receiving. The pitfall might be if your controllers start at the same time and both drive DE/RE# to HIGH (for transmitting) simultaneously. In the real world there may be some time discrepancies and you'll see the receiving at one side and prevent collision, but in the simulator your program flow will be absolutely the same.
Try one MCU to be the master and the second to be the slave. Multi-master communication using half-duplex transmission line is not such a simple task.
Zip and post your complete project files and also Proteus file.
Thank you very much to all for your kind help. Now My project is working flawlessly.
Since this is a forum, where other members should gain from the discussion...you should post where/what the problem was and how you solved it.
Klaus
This the circuit diagram
Code for MCU 1
HTML:
#include <avr/io.h>
#define MAXTTEpin 2
#define Led 1
#define Button 1
extern volatile char flag =0;
	  SET_MAXTE(PORTD,MAXTTEpin);									//Set Transmitter enabled pin
      _delay_ms(1);
	 _delay_ms(1);
ISR(USART_RXC_vect)
     cli();															 //Clear Interruppt
	 PORTA = UDR; 													 //send data to port A from UDR
     flag = 1;                                                       //Set Flag
    //_delay_ms(1);
/*Main Function*/
int main()
    char data=0;
	DDRA|=(1<<Led);                                                  //Make Led as Output
    DDRB&=~(1<<Button);   							                 //Make Button as Input
	while(1)
        if(flag)
		   data=PINB;                                              	//Take data from Pin B
		   RS485Transmitt(data);									//Transmitt Data
		   _delay_ms(1);
Code for MCU 2
HTML:
#include <avr/io.h>
#define MAXTTEpin 2
#define Led 1
#define Button 1
//extern volatile char flag =0x00;
      _delay_ms(1);
	 _delay_ms(1);
ISR(USART_RXC_vect)
    PORTA = UDR;
    //_delay_ms(1);                                                     //send data to port A from UDR
/*Main Function*/
int main()
     char data=0;
	 while(1)
			_delay_ms(1);
