problem of running IC5141 in Suse 9.3
lcking
Member level 1
waiting for ipc:0 to initialize
I have installed IC5141 in Suse9.3, but there are some problems in running IC5141. The startup speed of IC5141 is very slow. and when I click the menu "library manager...", IC5141 hangs.
This is the log of CDS.
\o
\o COPYRIGHT ?1992-2004 CADENCE DESIGN SYSTEMS INC. ALL RIGHTS RESERVED.
\o ?1992-2004 UNIX SYSTEMS Laboratories INC.,
\o Reproduced with permission.
\o
\o This Cadence Design Systems program and online documentation are
\o proprietary/confidential information and may be disclosed/used only
\o as authorized in a license agreement controlling such use and disclosure.
\o
\o RESTRICTED RIGHTS NOTICE (SHORT FORM)
\o Use/reproduction/disclosure is subject to restriction
\o set forth at FAR 1252.227-19 or its equivalent.
\p >
\o 8-bit PseudoColor Visual is not available (default Visual option).
\o Using 24-bit TrueColor Visual.
\o The program xdpyinfo can be used to verify the Visuals available
\o for your display.
\o Loading PRshare.cxt
\o Loading LVS.cxt
\o Loading acv.cxt
\o Loading auCore.cxt
\o Loading schView.cxt
\o Loading selectSv.cxt
\o Loading seismic.cxt
\o Loading UltraSim.cxt
\p >
\a hiResizeWindow(window(1) list(287:14 1012:175))
\r t
\a ddsOpenLibManager()
\o cdsServIpc: ipcIsAliveProcess connection timeout (host:martian)Waiting for ipc:0 to initialize
\o Waiting for ipc:0 to initialize
\w *WARNING* (ddsOpenLibManager) unable to connect to library manager (60 tries)
\r cdsServIpc: ipcIsAliveProcess connection timeout (host:martian)nil
Can anyone tell me how to slove these problems?
waiting for ipc 0 to initialize
Try change your IP adress in license files. I have this problem, when two computers have identical ip (hostname) in network. Also these problem exist then your ip adress don't coincide with ip in license file.
P.S. Don't forget start necessary network sevice !
ipcisaliveprocess connection timeout
You can get the answer on sourcelink.cadence.com
waiting for ipc to initialize
If he had a sourcelink account he probably wouldn't be asking here.
cdsservipc
you can try to set your "hosts" file in /etc as follow
127.0.0.1 yourcomputername
cdsservipc: ipcisaliveprocess connection timeout
can any of you direct me to a site where I can get a working Linux version for C@dence?
