HI friends,
a question on resistor matching. I am using the umc 130nm technology. As per the documents given the resistors can have a mismatch of upto ±10% betweent he actual value in the circuit and after fabrication. In my circuit i am using two resistors of same value and the value difference between them after fabrication shoudl be really low. taking the worst case as per umc process documents the tolereance they hae specified will give a large error assuming their is +10% error in the first resistor and -10% error in secodn resistor. Is their any way of balancing this mismatch during fabrication of the resistors.
Thanks for your help.
