[SOLVED] problem of “error: model *** not found” in Pspice
qssherman
Newbie level 2
Newbie level 2
(solved)problem of “error: model *** not found” in Pspice
Hi everyone:
I am learning to use Pspice and meet a problem.
I had build my own model and generated the .lib and .olb files.
However, when I use my own model such as a cmos in a design, the part can not connect with the model in .lib and .olb. When I try to click "Spice model" to try to connect it, the software show “error: model nmos not found” .
I had been frastrated with this problem in two days ~~~~(>_<)~~~~
Try including .lib created by you in simulation profile. This would make sure model nmos developed by you is available while simulation.
I had solved the problem, thank you very much! O(∩_∩)O~
